We are planning to connect our bathroom with our walk-in closet. We are considering not installing a door in the opening because both rooms are quite small. What are your experiences with moisture when no door is installed? Both rooms have skylights. I would appreciate your feedback.
O
Oetzberger11 Jul 2021 18:49In our house, the bathroom regularly turns into a complete steam room when someone takes a longer shower. And this happens despite having a ventilation system. I wouldn’t want that kind of climate in the dressing room. Better to keep the door closed and that’s that.
Schimi1791 schrieb:
If nobody minds when one… ‘nobody’ 🙄
nordanney schrieb:
To be honest, I wouldn’t want to go into the dressing room if my partner just had a half-hour session in the bathroom due to diarrhea or something similar. That’s what I wanted to convey… 😉
Although you could also see ‘convey’ here as a play on words.
hampshire12 Jul 2021 08:00Considering that a hinged door would be inconvenient, we installed a frosted glass sliding door to the bathroom. Access is through a part of the adjacent room, which could be described as a "dressing area."
The sliding door provides increased privacy when needed (however, even with the door open, a person showering or using the toilet cannot be seen) and serves as an effective barrier against odors and steam. Ventilation is provided by a patio door (north-facing) and a smaller window (west-facing), allowing for sufficient cross-ventilation.
Shower and dressing area without separation? ... I wouldn’t do that because of the moisture.
I would also avoid sliding doors (we have 2) if possible. The noise annoys me every time, and the movement of "sliding" – in my opinion – doesn’t go well with "walking through."
But as I said: sometimes sliding doors are the best solution.
Seven19843 Aug 2021 09:31It depends on the size... We have a bedroom with a walk-in closet and an en suite bathroom, which was described here as very stylish.
We also have a toilet inside.
The whole area is quite spacious at 53 m² (570 sq ft)... We don’t have any issues with moisture in the closets, but we also installed three exhaust vents in the living area... The sauna will be added next year, so we’ll see how the moisture situation is then.
Seven1984 schrieb:
We have a bedroom with a walk-in closet and an en suite bathroom.Our sauna is already installed. When using the sauna (70% traditional Finnish, 30% bio sauna), the bathroom door stays closed. If there is no frost, the window is tilted open.
After sauna sessions, we ventilate the bathroom, bedroom, and walk-in closet by cross-ventilation for at least 2 hours.
We have a cedar wood sauna, which we love for the scent, and a small pouch of cedar shavings placed between the pillows.
