ᐅ Single-Family Home – Design Planning – Request for Feedback
Created on: 8 Jan 2018 00:46
MBS2201
I would like to start a new thread regarding the initial design planning.
Previous thread: Single-family house – Opinions on our design
https://www.hausbau-forum.de/threads/Einfamilienhaus-Meinungen-zu-unserem-Entwurf.25622/
Here are the main points:
The foundation slab is already in place: 12.49 x 12.49 m2 (41 x 41 ft2) and 30 cm (12 inches) thick.
The foundation slab was inspected for quality by an energy consultant and a structural engineer – no issues were found.
The locations of the underground drainage pipes are marked in the image titled "Foundation Slab - Drainage Pipes."
The house is planned to be built on the existing foundation slab. Demolition is not planned.
The house needs to be constructed as a one-story plus attic (E+1) with a gable roof at a 22° pitch.
The original submission plan from the previous owner was applied for but has not been received yet.
Our own submission plan from the architect exists but was mostly rated as unsatisfactory.
Negative points in the submission plan:
  • Ground floor + upper floor
    • Staircase between ground and upper floor is not properly dimensioned
  • Ground floor
    • Staircase unsuitable, takes up too much space; entrance to living area is through the kitchen
    • Access from garage to house does not fit due to height differences
  • Upper floor
    • Staircase unsuitable, room layout and a dark hallway with hallway width only 1.10 m (3.6 ft)
    • Balcony extends across the entire house length
      • See east elevation under the image “View all sides”
        • The balcony was extended because the upper floor protrudes 70 cm (28 inches) beyond the ground floor, covering the resulting overhang. In the previous plan, the balcony was only above the bay window.
Our specific requests:
We like the ground floor and its room layout quite well. However, the half-landing staircase should be replaced by a space-saving alternative.
The staircase was placed centrally to allow the desired rooms to be created.
  • Keep the technical room in the marked position for connection reasons, near the turning circle.
  • Keep the front door position as shown – access from the garage plus guests parking in front of the garage.
  • Central staircase to maintain short walking distances.
  • Type of staircase: corner staircase with quarter turns (1x or 2x 90° turns) or straight staircase. Spiral staircases are not desired.
  • Modern house with an open kitchen and living area.
  • Home office.
  • Guest toilet with shower.
  • Pantry for freezer, food, and beverages.
  • Large children's bedrooms, preferably on the south side.
  • Room for a walk-in dressing area.
  • Separate entrance to the master bedroom, not through the dressing room.
  • One master bathroom and one children’s bathroom.
  • Small utility room (approx. 6–8 m2 (65–86 ft2)) on the upper floor for washing machine and dryer.
  • Tiled stove; the chimney flue should not run through the children’s bedrooms. Preferred route is through the bathroom or utility room.
Plot size: Parcel 35, 775 m2 (8,835 ft2)
KFW 55 standard
Slope: Yes
Site coverage ratio: 0.35
Floor area ratio: 0.80
Building envelope, building line, and boundary: see site plan
Edge development: No
Number of storeys: 2
Roof style: Gable roof, 22° pitch
Style / orientation: South - southeast
Maximum dimensions/limits: Building maximum = 14 m x 10 m (46 x 33 ft) plus single-story extension with max. length 10 m (33 ft), max. depth 3 m (10 ft)
Client requirements
Style, roof type, building type: Gable roof, 22° pitch
Basement, storeys: No basement, 2 full storeys
Number and ages of occupants: 4 persons (3 females, 1 male), ages 40, 38, 12, 9
Space requirements on ground and upper floors: Since no basement, more space per floor needed → approx. 90 m2 (970 ft2) per floor
Office use: Home office planned, possibly later converted to a bedroom / guests about 6 times a year
Open or closed layout: Open layout, at least on the ground floor
Traditional or modern design: Modern design
Open kitchen with island: Yes, open kitchen with cooking island
Number of dining seats: 1
Fireplace: Yes, should be placed in the living room, as the chimney should not pass through the children’s bedrooms.
Music / stereo wall: No
Balcony, roof terrace: Balcony: yes, roof terrace: no
Garage, carport: Double garage with partition
Additional wishes / special features / daily routine explanations:
Photovoltaic system + possibly battery storage, active ventilation system with heat recovery, air heat exchanger, cistern
Planner: Architect
- Company planner: No
- Architect: Yes
- DIY: No
What do you especially like? Why? Ground floor thanks to the open design with large windows
What do you dislike? Why? Upper floor layout
Estimated price according to architect/planner: ?
Personal budget limit for house including fixtures: 400,000 €
Preferred heating technology: Air heat exchanger with underfloor heating
If you had to give up something, which details or features could you do without?
- Can give up: Battery
Cannot do without:
Not a standard design from the planner, ideas based on model houses + floor plans found online + architect input
How can I improve the layout of the house?
Detailed site plan with building areas, paths, and green spaces
Site plan of a development area with lots, roads, green spaces, and building units
Construction plan of foundation slab with water pipes, drainage pipes, and cistern
Floor plan of a single-family house: kitchen/dining, living room, terrace, bathroom, garage.
Upper floor plan: bedroom, dressing room, bathroom, two children’s rooms, hallway, balcony.
Floor plan of a two-story house with living area on ground floor and bedrooms upstairs, courtyard.
Multiple views of a modern house: east, south, west, north elevations and cross-section
Floor plan of a house with basement and ground floor: kitchen, living room, hallway, bathroom, technical room, terrace.
Open floor plan of living and dining area with kitchen island, dining table, and sofa lounge.
Apartment floor plan: bathroom with bathtub, kitchen, bedroom with bed, living room with table.
MBS2201
8 Jan 2018 16:56
kaho674 schrieb:
Isn't a large city villa with a hipped roof possible?
Definitely only a gable roof is allowed. I checked with the local authority.
11ant8 Jan 2018 17:05
MBS2201 schrieb:
Style, roof type, building type: gable roof, 22° pitch
Basement, floors: no basement, 2 full floors
More precisely: a maximum of two full floors – this requirement is not circled for the main building.
kaho674 schrieb:
Can the garage be located 1m (3 feet) away with a covered walkway and stairs in between, or does it have to be directly attached to the house? I mean, because of the difference in height?
The garage position in the development plan only defines building boundaries; the building line applies only to the main building.
Kekse
8 Jan 2018 21:17
kaho674 schrieb:
You don’t hang laundry indoors, only use a dryer in winter? Isn’t that a huge waste of energy?
OT: No, it isn’t. As long as you use an efficient dryer (a heat pump model), the difference compared to drying clothes on a drying rack in a heated(!) room is minimal or, depending on the combination of the dryer and heating system, it can even be better. The evaporation energy is provided by the dryer in the dryer, otherwise it comes from the heating system. For each load of laundry, you have about 2 liters (0.5 gallons) of water that you need to ventilate out more when drying on a rack (and even with a heat-recovery ventilation system, that evaporation energy is lost). In a dryer, you remove this water in liquid form, so the energy has already been released. Almost all electrical energy consumed by the dryer is ultimately released as heat into the surrounding area—which in winter is not lost but rather reduces the load on the heating system.
kaho6748 Jan 2018 21:50
Kekse schrieb:
Off-topic: No, it isn’t. As long as you use an efficient dryer (meaning a heat pump model), there isn’t much difference compared to air-drying on a drying rack in a heated room, or depending on the combination of dryer and heating system, it can even be better. The energy for evaporation is provided by the dryer itself; otherwise, it would come from the heating system. For each load of laundry, you have about 2 liters (0.5 gallons) of water that you need to ventilate more when air-drying on a rack (and even with a heat recovery ventilation system, the energy for evaporation is lost), whereas the dryer disposes of it in liquid form, so that energy is given off already. Almost all the electrical energy consumed by the dryer is eventually released as heat into the surrounding environment—which in winter is not lost but actually reduces the heating demand.
You explained it beautifully, but sorry, I just can’t believe it.
77.willo8 Jan 2018 21:56
I find that questionable. The energy required for evaporation is relatively low compared to heating to the elevated temperature and the continuous drum rotation, etc.
MBS2201
8 Jan 2018 23:48
Since a photovoltaic system will be installed, I consider energy consumption to be uncritical. Laundry will just need to be dried during the day. Possibly a battery will be added later, allowing the machine to run at any time of day. Therefore, I want to reduce the utility room to about 6-8m² (65-86 sq ft). Besides the washer/dryer, laundry basket, ironing board, and vacuum cleaner, nothing else will go in there.
Ironing is done in the bedroom, where the walk-in closet is right next to it, and a TV will also be placed there.
