ᐅ My pet often leaves small pressure marks on the Kallax shelves – is there a protective coating to prevent this?
Created on: 2 May 2017 08:17
florian2
Hello everyone, I have a small but somewhat annoying issue with my Kallax shelf: My pet, specifically my cat, repeatedly causes very small dents on the surface of the shelf, especially on the corners and edges of the shelves. These dents are not deep but are visible and bother me aesthetically. The shelf is placed in a spot where my cat often leans or climbs up. Now I’m wondering if there is a gentle, preferably transparent coating that can be applied to this material (mostly melamine-coated particle board) to protect the wood from these minor damages without affecting the appearance. Ideally, it would be something non-toxic in case my pet licks it with their paw. Does anyone have experience with this or can recommend a specific solution? Thanks in advance!
kuben
2 May 2017 11:41
A brief guide on protecting your Kallax shelf:
1. First, clean the surface thoroughly to remove dust and grease (e.g., with isopropanol or mild dish soap and water).
2. Choose between a protective film (self-adhesive, transparent) or a liquid coating (acrylic or polyurethane varnish).
3. For films: Make sure to cut precisely to avoid overlaps and air bubbles.
4. For varnish: Apply several thin coats, sanding lightly between layers if needed to ensure optimal adhesion.
5. Allow drying and curing time as specified by the manufacturer.
Tip: Look for finishes labeled as “child- and pet-friendly furniture coatings” for pet-safe options. Ask your specialist retailer for health-safe products with appropriate certifications.
Teonon
2 May 2017 12:15
That’s brilliant! I really like that you’re putting so much thought into protecting your beloved pet and your shelf 🙂 I would try using a high-quality, transparent protective film. You can easily replace it, and it leaves no residue. Maybe the kind used for phone screens? 🙂
florian2
2 May 2017 14:37
Thanks for all the helpful tips!
Van_pe schrieb:
Furniture protective films (clear) ... for example, those used for car paint...
That sounds very interesting, especially since I need some flexibility around the corners.
tangi schrieb:
Acrylic paint for furniture surfaces that remains almost transparent
Do these paints leave the surface relatively non-slip? My cat often climbs on it, and a surface that is too smooth could cause problems.
Also, just to be sure: Are these films and paints really safe if the cat occasionally touches the surface with its paw or nose? I want to avoid anything that might release harmful substances.
tangi
2 May 2017 15:02
A good question. Most high-quality acrylic paints dry to a matte or satin finish and generally provide a slightly tacky surface that is not too smooth. Pay attention to the product description and tests regarding slip resistance (sometimes classified as surfaces rated R9 to R13).
Regarding safety: Most professional furniture paints now have low-VOC and non-toxic formulations, especially when explicitly labeled as "pet-friendly" or "child-safe." Complete curing before use is essential.
mintra
2 May 2017 15:38
Regarding safety, I can add that even surface sealants, which are officially considered safe, usually require a curing period to ensure that no volatile organic compounds continue to off-gas. This means the room must be well ventilated, and furniture should only be placed near pets after at least 48 hours of complete drying and curing.
These instructions can be found in the official Safety Data Sheets (SDS) of the products, which should be publicly accessible to enable well-informed decisions.
tralo45
2 May 2017 16:12
To summarize again, and also for those who may have less experience with paints and films:
- For films: Apply them carefully to avoid air bubbles or wrinkles
- For paints: Test a small area in an inconspicuous spot
- Pay attention to sealed surfaces that are specifically labeled as child- and pet-friendly
The most important thing is not to stress your pet and to ensure there are no sharp edges or strong chemical odors that could bother the animal over a longer period.
