ᐅ How can I apply adhesive films neatly onto Pax surfaces?
Created on: 29 Mar 2018 09:37
Marzar43
I’m currently facing the challenge of how to apply self-adhesive films neatly onto Pax surfaces. Specifically, I want to make sure the films neither bubble nor peel off at the edges. I have furniture with smooth, coated fronts where the film should adhere as smoothly and permanently as possible. Unfortunately, I haven’t found any good guides that focus specifically on the smooth surface of Pax.
I would appreciate any tips on how to best prepare and apply the film, whether tools like a squeegee should be used, which techniques have proven effective, and how to work as bubble-free as possible. Advice on cleaning the surface before applying the film or tricks in case bubbles do appear would also be extremely helpful.
Thank you in advance!
risar
29 Mar 2018 11:53
Hello Marzar43,
regarding your question about positioning: A proven method is the so-called wet application. In this process, you lightly spray the surface with water and a little dish soap before placing the film. This allows you to adjust the film until it is perfectly aligned. Once the position is correct, you squeegee out the liquid, and the film adheres firmly.
This works especially well on smooth surfaces like those of Pax. However, be sure to use a film that is suitable for wet application to prevent the adhesive from being deactivated prematurely.
Please make sure to press down all edges firmly and allow the surface to dry completely afterward.
Good luck!
Louie
30 Mar 2018 08:42
Marzar43 schrieb:
Are there any smart techniques that allow for some play, or should you start firmly at the top and then work your way down slowly? What works best for such large sheets?
I would recommend positioning the sheet roughly with some gap first, so don’t press it down completely right away. If you have a self-adhesive film, you can partially peel off the protective backing, align the film at the top edge, and then slowly pull it down step by step while simultaneously using a squeegee to push out the air.
If possible, make sure to thoroughly clean the surfaces beforehand with a grease-free cleaner (isopropanol). And if you have a heat gun, you can gently warm the film after application to help it conform better and relieve tension.
BLAKEO
30 Mar 2018 09:33
Louie schrieb:
And if you have a heat gun, you can gently warm the membrane after installation to help it conform better and release tension.
I know this is often recommended, but can it really not damage the material over time? Especially with thinner membranes, there is a risk that too much heat could harm the adhesive or the membrane itself. I would advise using a very low temperature and warming only gently with a light “massaging” motion. Does anyone have specific experience regarding how hot or how long one should use a hairdryer or heat gun for this?
enrique7
30 Mar 2018 10:12
BLAKEO schrieb:
I know this is often recommended, but can it really not damage the material in the long run?
That’s a valid point. Studies on adhesive films show that excessive or prolonged heat can degrade the adhesive quality and cause the film material to warp or discolor.
I recommend applying heat very carefully and strictly following the manufacturer’s instructions. It’s better to use less heat and repeat the process multiple times rather than applying high heat all at once.
It is also crucial that the surface of the Pax is completely dust- and grease-free before application, as this has by far the greatest impact on durability and the visible results.
GEKAU51
31 Mar 2018 12:14
I am still somewhat surprised by how critical some people are about adhesive application here. I wonder if it is more a psychological issue than a technical one. Of course, if you use high-quality film, work carefully, and exercise a bit of patience, the result can be impressive for many years.
I believe that film peeling off or even damaging the surface is more likely the result of improper handling or incorrect removal rather than the adhesive application itself.
If someone truly wants a durable and attractive finish, they might want to consider options beyond film. However, when it comes to applying film on Pax surfaces, in most cases, anyone who works with some care should have no trouble.
Marzar43
1 Apr 2018 09:22
Thank you very much for the many helpful replies and interesting objections. In summary, I now understand that the following points are especially important for a clean and durable result:
- Thorough cleaning of the Pax surface, free of grease and dust
- If necessary, wet application using a dish soap and water mixture to facilitate positioning
- Gradual removal of the protective film while simultaneously pressing down with a squeegee
- Positioning possible due to some play during wet application; otherwise, apply gradually from top to bottom
- Careful reheating with a heat gun only at low temperature and in short intervals
- Gently puncture bubbles with a needle and smooth out
I will try it this way and report back. If anyone has additional tips regarding brands or types of films that adhere particularly well to Pax, I would appreciate the information!
