I have several Malm dressers from IKEA in my apartment, which I mainly use in the bedroom. Due to the slightly higher humidity, especially during the cooler months, I am concerned about potential moisture damage, such as swelling or warping of the surface.
My question: What practical and effective measures can you recommend to protect Malm furniture specifically from moisture damage?
I am interested in both preventive tips (e.g., protective treatments like oils or varnishes) and everyday habits to keep in mind. Also, are there any special considerations regarding the material (particleboard with laminate coating) that should be taken into account to extend the furniture’s lifespan?
Thanks in advance for your help!
V
valerie-tr21 Oct 2018 09:23Hello Adolf43,
Your concern is quite valid, as furniture from the Malm series can be more susceptible to moisture due to their construction using particleboard with a foil laminate.
First, it is important to understand that the protective foil itself is relatively resistant to moisture as long as it is not damaged or torn. The main risk is that moisture can penetrate into the particleboard at exposed edges or scratches. This can then cause swelling and deformation.
My recommendation includes several steps:
1. Visual inspection and edge protection: Check all edges and areas, especially the back and inside surfaces, for any damage. You can treat exposed edges with a special acrylic-based edge sealer to prevent moisture from entering.
2. Dust and humidity control in the room: Make sure the relative humidity ideally stays between 40 and 60%. Use a dehumidifier and ventilate regularly if necessary, but avoid placing drinks or wet objects directly on the furniture.
3. Protect vulnerable areas from moisture: Use felt pads under vases or similar items, and do not place wet cloths on the surface when cleaning.
4. Additional surface protection is only advisable in very specific cases, since the foil laminate is already sealed – applying varnishes or oils can even be counterproductive if the products are not compatible.
One question I have: Are your furniture located in a colder, more humid room, or are there specific areas with moisture problems (condensation, water splashes, etc.)?
valerie-tr schrieb:
One more question: Are your furniture pieces located in a colder, more humid room, or are there specific spots with moisture issues?Thank you for the detailed response! The furniture is in my bedroom, which is regularly heated and ventilated, but in the mornings there is often condensation on the windows. However, the furniture is not placed directly next to the windows – the distance is about 50 cm (20 inches). So, the room is not unusually humid, but I do notice some minor signs of slight swelling on the edges, probably caused by occasional moisture peaks. Nothing more than that.
Can you say whether applying an additional protective varnish on the edges is really worthwhile? Or is it enough to just check them regularly?
V
valerie-tr21 Oct 2018 11:05Regarding
I would definitely recommend addressing the edge protection actively. Although the foil coating is durable, the chipboard underneath is sensitive at joints and edges.
Use a waterproof acrylic or edge-sealing product applied to the edges to seal the chipboard. These products are specifically designed to keep moisture out without affecting the appearance.
Some DIY enthusiasts also use a clear water-based furniture varnish, but caution is advised: not all varnishes adhere well to foil, which can cause peeling. Therefore, it’s better to use a product made specifically for edge sealing.
In addition to prevention, consistently controlling the indoor humidity is important. A hygrometer is very useful for bedrooms.
One more question: Has the piece of furniture ever been damaged or repaired anywhere where the protective foil is missing or torn?
Adolf43 schrieb:
small signs of slight swelling at the edges
valerie-tr schrieb:
Has the piece of furniture ever been damaged or repaired afterward, where the protective film is missing or torn?Yes, I accidentally hit one edge some time ago, causing a small area of the film to come off. It is about 2 x 3 cm (0.8 x 1.2 inches) in size.
That might be exactly where the slight swelling starts. So sealing it there probably does help.
Where can I usually get edge sealing products? A hardware store, or specialized online shops? What should I look for when buying?
V
valerie-tr21 Oct 2018 12:29Exactly,
is always the weak point for moisture. In such areas, water can easily penetrate and cause the particleboard to swell.
Edge sealing products are usually available at specialist retailers, large hardware stores (e.g., home improvement centers, DIY stores) or various online shops for furniture accessories. Pay attention to the following points:
- Water resistance
- Good adhesion to particleboard and membrane
- Transparency, if the appearance should be preserved
- Easy application (usually brush or pen)
Common products are, for example, water-based acrylic edge sealers. Some people also use solvent-based varnishes, which offer better sealing but are more difficult to apply.
My tip: Lightly sand and thoroughly clean the area to be treated before application – this improves adhesion. Then allow sufficient drying time.
If you like, I can find some specific product recommendations for you. It would also be interesting to know how often the furniture is checked for moisture. Do you already have a fixed inspection schedule?
Adolf43 schrieb:
small spot of the membrane chipped off
- Water resistance
