ᐅ Malm Furniture with Water Stains – Which Home Remedies Are Recommended?
Created on: 20 Dec 2023 09:17
fu-arkadi
Hello everyone, I recently bought a Malm wardrobe from IKEA, which unfortunately has developed some small water stains on the surface. These are not deep scratches, but rather dull, white spots that likely resulted from moisture. My question is: What proven home remedies do you recommend for effectively and gently removing these water stains from Malm furniture without damaging the surface?
I am especially interested in whether simple kitchen ingredients like vinegar or baking soda are suitable, or if more specialized care products are necessary. Thank you very much for your advice!
koduga
21 Dec 2023 10:10
Great guide, thanks! I’ve tried the iron method once as well, but more as a last resort. The important thing is to be patient and never use too much heat.
If the stain just won’t come out, it’s worth considering a new furniture polish with a slight satin finish. This often masks stains better than cleaning alone.
nojaus
21 Dec 2023 11:57
I would like to briefly point out: When it comes to home remedies, not every method works equally well for every stain. Water stains can vary depending on the cause – some affect only the surface, while others have more seriously damaged the protective layer.
Stay calm and try the methods that seem most suitable for your situation.
When in doubt, gentle cleaning is the best approach. It’s better to clean gently more often than to aggressively scrub the surface with harsh materials.
meGreg
21 Dec 2023 12:45
A small personal tip from me: Sometimes a leather care cloth can help reduce those small scratches and marks on high-gloss furniture.
Just gently wipe over the surface; it often works wonders without damaging the finish.
Some call it the 'gentle magic trick' against water stains – I can only recommend it 🙂
