ᐅ Malm Furniture with Water Stains – Which Home Remedies Are Recommended?
Created on: 20 Dec 2023 09:17
fu-arkadi
Hello everyone, I recently bought a Malm wardrobe from IKEA, which unfortunately has developed some small water stains on the surface. These are not deep scratches, but rather dull, white spots that likely resulted from moisture. My question is: What proven home remedies do you recommend for effectively and gently removing these water stains from Malm furniture without damaging the surface?
I am especially interested in whether simple kitchen ingredients like vinegar or baking soda are suitable, or if more specialized care products are necessary. Thank you very much for your advice!
Water stains on Malm? That sounds like a nightmare at first! 🙂 I once tried using some toothpaste, the classic white kind, not the gel type. Put a little on a damp cloth, gently rub it over the stain, then wipe it off.
It worked well for me, and the nice thing is you also get that “remix” feeling, like you’re revitalizing your piece of furniture 😉 Good luck!
meGreg schrieb:
Water stains on Malm? That sounds like a nightmare at first! 🙂Haha, exactly! But hey, it’s great that toothpaste works, I wouldn’t have thought of that! Thanks for the tip, I’ll try it on my table right away :-)
Leote schrieb:
Spray vinegar and water in a 1:1 ratio, let it sit briefly, then wipe off with a dry cloth. Works well on white stains. But test first!Right, caution is key here! Safety always comes first. Everyone, remember: test, test, test!
An important point I’d like to add: water stains on melamine-coated furniture often result from prolonged exposure to moisture, which can soften the material or cause slight cloudiness.
A proven method, as already mentioned here, is to use a slightly damp cloth with a bit of furniture polish based on wax or polyurethane to reseal the surface.
Under no circumstances should aggressive chemicals be used, as they can damage the protective layer. Additionally, an iron set to a very low temperature can provide gentle heat to evaporate water stains, but only with a cotton cloth in between and applying very light pressure.
fu-arkadi21 Dec 2023 08:55Thank you very much for the detailed and valuable advice so far!
I will try the suggestions using a vinegar-water mixture, toothpaste, and olive oil. I am particularly interested in how well an iron works for dehumidifying – this is an intriguing approach but also somewhat risky.
Has anyone already tried a reliable guide for this method? What temperature is definitely safe to avoid damaging the melamine coating?
fu-arkadi schrieb:
Has anyone already found a reliable guide for this method?Yes, I can briefly explain it:
1. Set the iron to the lowest setting, ideally the one for synthetics or the "cool" setting.
2. Place a clean, dry cotton cloth (e.g., a tea towel) over the stain.
3. Glide the iron over the cloth very briefly (maximum 5–10 seconds) without applying pressure.
4. After each attempt, lift the cloth and check if the stain has changed.
The goal is to gently warm the moisture out of the paint, not to burn or melt it.
However, this method is not completely risk-free. It’s best to test it first on an inconspicuous area.
