ᐅ Is there a recommended order for assembling Ikea PLATSA?
Created on: 3 Jul 2019 14:27
Rasim40
Rasim40
3 Jul 2019 14:27
I’m planning to install a PLATSA system at home and wondering if there’s a suggested sequence for assembly to avoid mistakes or make the process more efficient.
I have reviewed the instructions, but it seems they sometimes present the steps in a somewhat mixed order or allow for several parts to be assembled in parallel.
For example, I’m unsure whether it’s better to start with the basic components like the frames and back panels or to install the rails and drawers first.
Do you have any experience or tips that could make the assembly easier or save time?
Looking forward to your opinions and advice!
kla69
3 Jul 2019 16:42
That is a very valid question that actually comes up quite often with PLATSA.
Basically, I always recommend carrying out the assembly in a well-thought-out order, as the system includes several components that are designed to work together.
My tip: definitely start with building the frame, including the side panels and the base. These form the structural core and ensure that the entire unit stands stable.
Rasim40 schrieb:
For example, I wonder if it is better to first assemble the basic parts like the frame and back panels, or if you should install the rails and drawers first.
Exactly. Installing the rails and drawers only makes sense once the frame is fully assembled and the back panel is mounted, since the rails are often attached to these. Another important point is to observe the correct torque for screws; overtightening can cause the wood to split, while too loose screws will reduce stability.
Also, you should make sure to sort all the parts before starting the assembly. This helps to avoid minor damages more easily. I usually create a checklist and work step by step — this prevents mistakes and saves you from having to take things apart afterwards.
One more question for you: How large is your PLATSA system? Are you planning several modules side by side or a single unit? Depending on that, the assembly order can vary slightly, especially when connecting the modules to each other.
fiman
3 Jul 2019 18:03
Build the frame, attach the back panels, then install the rails and drawers. This is usually the best sequence for practicality.
Teonon
4 Jul 2019 08:17
I can only confirm that the order really makes a big difference! 🙂
At first, I installed the rails before the frame was properly assembled – that was a real mess! 😅
My advice: First, build everything correctly and securely fasten it, then calmly insert the drawers. That way, assembling is much more enjoyable and less stressful!
Plus, it gives a great sense of accomplishment to see the system come together step by step. You’ve got this! 😄
botibo
5 Jul 2019 09:46
I agree with the others here – first the frame, then the back panels, and finally the rails, doors, and drawers.
If you take some time sorting the parts beforehand, assembling will be much more enjoyable, as chaos quickly leads to small frustrating moments.
I’ve made a habit of organizing screws and small parts into little bowls according to the steps, which turns the whole process more into a small puzzle than a construction site.
And don’t worry, with every screw, the PLATSA chaos becomes more orderly! 😉
