ᐅ How do I plan large projects involving multiple Ikea Platsa units?
Created on: 27 Nov 2022 14:38
U
Usso61
Hello everyone, I am currently planning a larger residential project where I want to combine several Ikea Platsa units to create customizable storage and flexible room layouts. My specific question is: How do you approach planning such complex modules when it comes to room dimensions, load distribution, variety of options, and the efficient use of the Platsa units? Are there general strategies or tools that have proven effective for large projects using Platsa? I want to avoid running into problems later, such as incorrect measurements or insufficient stability, so I am looking for a structured planning approach. Thanks in advance for your experiences and tips!
Tofra45
28 Nov 2022 10:32
Additionally: To manage the variety of Platsa modules effectively, it is recommended to plan using a base grid of 40cm (16 inches). This ensures that all modules and inserts fit together easily. This way, you avoid fitting issues and can expand flexibly later on.
Kenon70
28 Nov 2022 12:05
I would say: first plan your main structure with the large modules, then add smaller modules and interior elements. It is also important to consider access, ensuring that doors or drawers are not obstructed.
U
Usso61
28 Nov 2022 15:18
Thanks for the initial tips! I have another question: How did you address stability in your large projects with Platsa when multiple modules are assembled together? I understand that the modules can be connected, but do the connections provide enough stability against tipping or bending? Should additional brackets, screws, or other reinforcements be used? Do you have any practical experience or recommendations on this? It would be great if you could share details about the specific types of connections you used.
Guyju
28 Nov 2022 16:47
Usso61 schrieb:
Does anyone have practical experience or recommendations?
Yes, definitely! It is important not to secure the modules only with the Ikea connectors but also to reinforce them internally at certain points with metal brackets or wooden strips. Additionally, you can strengthen the back panels or install a plywood backing – this greatly increases resistance to twisting and tipping.
If the project is very large, also plan for floor anchoring, for example, a strip to fix the furniture at the bottom. This provides extra stability.
For assembly, a cordless drill with a depth stop is useful to avoid over-tightening the screws.
Summary:
- Use Ikea connectors
- Screw in additional brackets inside
- Strengthen or replace back panels
- If needed, fix to the floor
This way, the system will hold up reliably even for large-scale setups.
Tobias
29 Nov 2022 08:26
Guyju schrieb:
Attach additional corner brackets inside
I agree, that can’t hurt. If you don’t want to do that, make sure the load is distributed evenly and secure the modules to the wall. This will significantly reduce the risk of tipping.
