ᐅ How quickly can the Ikea Platsa system be disassembled and reassembled?
Created on: 15 Mar 2024 08:12
Seanle
Hello everyone, I’m currently planning a move and considering disassembling my Ikea Platsa shelving unit to reassemble it at the new place. I’m particularly interested in how quickly the Ikea Platsa can be taken apart and put back together. It’s important for me to know whether this can be done easily by one person or if it’s better to work with two. Additionally, I would like to find out if any special tools are needed and if there are common pitfalls that might slow down the process. I want to have a realistic estimate of the time required so I can plan the move accordingly. Thanks in advance for your experiences!
Time Estimate for Disassembling and Assembling Ikea Platsa: On average, assembly takes about 1.5 to 2 hours for a unit approximately 1.5 meters wide (5 feet) when two people are working. Disassembly tends to be faster since it usually involves only loosening screws and removing components without reassembling. It is important to work systematically and avoid damaging any parts.
The following tips are helpful:
- Label or photograph all parts systematically in advance
- Collect screws in small containers to prevent loss
- Prepare tools: Phillips screwdriver, possibly a cordless drill with low torque
- Remove drawer and door assemblies before disassembly to save time
This approach allows you to better plan the time required and minimize surprises during assembly.
Hello Seanle,
I understand your concern and can share from my own experience the following: The speed of disassembling and assembling Ikea Platsa units depends greatly on the specific configuration. A simple shelving unit without doors or drawers goes much faster than a more complex setup. It is important to disassemble step by step in an organized manner to avoid stress during reassembly. Drawers should be removed first to prevent jamming, and it’s best to unhinge the doors. You can manage the assembly alone, but having a second person helps with holding and aligning the larger panels. Tools: A good Phillips screwdriver and possibly a small cordless drill will make the process much easier.
I also recommend including a 20-30% time buffer in your schedule in case unexpected issues arise.
draleo schrieb:
Dismantling tends to be faster since it usually involves only unscrewing and removing components, without reassembling anything.That sounds reasonable. So, should I expect dismantling to be about 25-30% faster than assembly?
Is there anyone here who has done this with a larger Platsa configuration (e.g., two units combined) and can confirm the time estimates? Would the times simply add up, or are there efficiency gains?
From experience: Dismantling usually goes faster because you don’t have to assemble components. With two units, the time needed is not simply double, as some tasks can be done in parallel – working in pairs is a clear advantage. Note: Make sure to properly remove doors and drawers, otherwise it will take longer.
gasidney schrieb:
With two people, you don’t simply double the time, as some tasks can be done in parallel – having two people is definitely an advantage.That’s true, two helping hands significantly reduce the effort. The difference is especially noticeable when holding large parts in place.
Thank you for your input! It helps to have a more realistic understanding of the process. In summary, I see that Ikea Platsa modular shelves tend to take slightly less time to dismantle than to assemble. Two people are definitely beneficial, especially because of the larger components. A Phillips screwdriver and a cordless drill can make the job easier. It also seems helpful to remove the drawers and doors beforehand and to take photos for reference before starting the disassembly.
Does anyone have additional tips on how to make the process particularly time-efficient or stress-free? For example, tricks for sorting screws or specific sequences that have proven effective?
