ᐅ Is the painted surface on the Kallax more prone to damage compared to other furniture?
Created on: 8 Feb 2019 09:17
Nijuri
Nijuri
8 Feb 2019 09:17
I have a specific question that has been on my mind for a while: Is the lacquer finish on the IKEA Kallax shelf actually more prone to damage than the surfaces of other comparable furniture pieces?
To explain a bit further: I own a Kallax with the typical white lacquer finish and have noticed an increasing number of small scratches and marks, which seem less noticeable on other furniture with different finishes. I am also interested in whether the material and type of lacquer are crucial factors here, and if there are any concrete insights or experiences that support or contradict this impression.
Perhaps some of you have consciously made comparisons or know about the differences in surface durability? I would like to understand whether Kallax is mainly a visually appealing but vulnerable piece of furniture, or if that impression is misleading.
Thanks in advance for your input!
Tause
8 Feb 2019 09:43
Basically, when addressing a question like this, it’s important to first clarify what exactly is meant by “more prone to damage.” Are we talking about scratch resistance, impact resistance, or general wear and tear? The term “painted surface” is quite broad and can vary significantly in its application.
Nijuri schrieb:
I own a Kallax with the typical white painted surface and have noticed an increasing number of small scratches and dents
As far as I know, Kallax uses a melamine resin coating, which is somewhat more durable than conventional paint. However, scratches tend to be more visible on white, glossy surfaces. In this case, the _visual_ susceptibility might be greater than the actual weakness of the material.
Additionally, it’s worth considering that other furniture might be covered with foil or different surface sealants that are either thicker or more flexible, which can make damage less noticeable. But do you have specific pieces to compare? Without a point of reference, any assessment is difficult.
meoka
8 Feb 2019 10:05
Additionally, I would like to explain how surfaces on furniture are typically treated and what to consider when evaluating their durability.
1. Core material: Kallax is usually made from particleboard or MDF, which react differently to coatings.
2. Type of finish: PU (polyurethane) finishes, for example, are very resistant to scratches and moisture, while acrylic or dispersion paints tend to be more vulnerable.
3. Application method: The finish can be painted, foil-wrapped, or laminated; this makes a significant practical difference.
To my knowledge, Kallax uses a thin, certified melamine resin layer on the white lacquer surface, which is relatively durable but can still show visible signs of wear from sharp objects or hard impacts.
Common mistakes in care include:
- Cleaning with harsh chemicals
- Placing sharp objects directly on the surface without protection
- Not avoiding direct sunlight, which can cause the finish to fade
In summary: The Kallax surface is not inherently weaker, but depending on use and care, damage may appear more quickly. Comparing it to other furniture only makes sense if you know the exact surface characteristics.
JORDON
8 Feb 2019 11:22
Tause schrieb:
scratches are naturally more noticeable on white, glossy surfaces
Haha, I think that’s the main issue with Kallax: the scratches are just very visible! Especially when you have kids in the house, it starts to look like the shelves have been through a battlefield. 😉
But seriously: I once covered a Kallax with a adhesive film (like a sticky foil over the lacquer surface), and behold – it not only looks better but also surprisingly protects well against scratches. So if anyone is struggling with its vulnerability, that could be an easy solution.
I don’t think the lacquer itself is weaker, rather it’s just not particularly resistant to everyday wear and tear. It’s basically furniture meant for gentle use. 🙂
theota
9 Feb 2019 07:13
I find the discussion here interesting, but I would like to put forward a provocative statement:
JORDON schrieb:
I don’t think the paint itself is weaker per se, rather that it is not particularly resistant to everyday wear and tear.
Isn't that almost the same thing? I believe the issue is that IKEA, when optimizing costs, doesn’t necessarily use the toughest coating, but rather the one that looks good enough and suits the price range.
Other manufacturers often use thicker, harder paint layers or even special coatings (e.g., nano coatings) for comparable furniture, which would be too expensive for mass production of the Kallax.
This means that the paint surface on the Kallax is not only more prone to damage but that this is also consciously accepted to keep the price low.
Are there any solid tests or comparisons on this matter?
FAZAR
9 Feb 2019 10:48
Hello everyone, I would like to take a closer look from a technical perspective, as the discussion so far seems somewhat superficial to me.
The surface of the Kallax shelf consists – as mentioned several times – mainly of a melamine-coated chipboard or MDF.
Technically speaking:
- Melamine resin coatings are relatively resistant to scratches, heat, and moisture. However, they are not as flexible as varnish, so strong impacts or sharp objects can damage the material beneath the coating.
- Higher-end furniture often uses UV-cured varnishes or thick multi-layer coatings (PU or epoxy resin), which are significantly more resistant.
- Additionally, the coating thickness can vary. For the Kallax, it is usually a thin layer to keep the furniture lightweight and to prevent the coating from chipping.
My conclusion: For the price, Kallax comes with a durable surface – but compared to high-quality furniture with thick or specialized varnish or sealants, the surface is more vulnerable.
One more question to the original poster: How intense and in which situations does the damage occur for you? That could greatly affect the wear and tear.
