ᐅ Is it possible to replace the back panel of a Pax wardrobe with a glass panel?
Created on: 2 Jun 2023 08:17
Ludeo0Hello everyone, I am planning to customize my IKEA Pax wardrobe and am currently considering whether it is technically possible and advisable to replace the standard wooden back panel with a glass panel. My idea is to visually lighten the wardrobe and allow some light to pass through from the back.
My specific questions are:
- Is it even feasible to replace the back panel with glass without compromising stability?
- What should be taken into account regarding load-bearing capacity, fixing methods, or structural stress?
- Are there any recommendations for the optimal type of glass (e.g., safety glass, certain thickness)?
- Or would you advise against it for practical, safety-related, or cost reasons?
I look forward to your experiences and professional assessments!
In principle, it is possible to replace the back panel of a Pax wardrobe with glass, but there are several technical and safety considerations to keep in mind.
The original back panel does not only serve an aesthetic purpose but primarily has an important structural function: it stabilizes the construction and prevents twisting or tipping. A glass back panel system would therefore need to provide at least the same level of stability, which is not easy to achieve.
If glass is used anyway, I recommend:
- Using safety glass (e.g., toughened or laminated), at least 4-6mm (0.16-0.24 inches) thick
- Professional framing or mounting solutions, preferably with rubberized holders
- Additional braces or stabilizers to ensure the overall stability of the wardrobe
DIY solutions without experience could be problematic and may compromise safety.
Genevieve2 Jun 2023 09:45[@Joshbe, post: a5p3p1, member: XXX]The original back panel serves not only as a visual element but also has an important structural function: it stabilizes the construction and prevents twisting or tipping.[/quote]
This is an important point.
I would also add that many people often underestimate the load on support surfaces and possible pressure points during such modifications. Glass is stable but can break or chip, for example, if the cabinet is moved or something hits the back panel.
Furthermore, I wonder how moisture regulation inside the cabinet changes. The original back panel made of wood or thin chipboard at least allows some air circulation, whereas a glass back panel might reduce air exchange inside the cabinet. This could have long-term effects on the sensitivity of stored items.
Good morning,
I would like to approach the topic from a practical perspective. If you want to replace the back panel of your Pax wardrobe with glass, you should be sure how the glass will be cut and whether you can properly carry out the installation yourself or will need professional help.
The method of attachment is also crucial. Standard Pax screws and clips are designed for thin particleboard, so you may need completely different fittings for the glass.
Alternatively, you could consider making a type of glass panel with a frame (for example, aluminum or wood) as the back panel. This provides more stability and a secure way to fasten it.
Oh, and if the wardrobe is already assembled and standing, it’s a good idea to test how stable the structure is without the back panel first. This will give you valuable information for your construction.
Hey! The idea of using a glass backsplash sounds really stylish and modern, no doubt. 😎
However, safety should not be overlooked. Glass shards from an accidental impact could cause serious injury. If you decide to go ahead with it, make sure to use tempered safety glass (ESG) – it breaks into small, harmless pieces.
I also think it would be great to have the glass frosted or printed with a pattern. That way, it not only looks good but also offers some privacy or conceals certain areas.
And if you add an LED strip, you’ll have a nice ambient light behind the cabinet.
Good luck with your project!
