ᐅ Is it possible to replace the back panel of a Pax wardrobe with a glass panel?
Created on: 2 Jun 2023 08:17
Ludeo0
Hello everyone, I am planning to customize my IKEA Pax wardrobe and am currently considering whether it is technically possible and advisable to replace the standard wooden back panel with a glass panel. My idea is to visually lighten the wardrobe and allow some light to pass through from the back.
My specific questions are:
- Is it even feasible to replace the back panel with glass without compromising stability?
- What should be taken into account regarding load-bearing capacity, fixing methods, or structural stress?
- Are there any recommendations for the optimal type of glass (e.g., safety glass, certain thickness)?
- Or would you advise against it for practical, safety-related, or cost reasons?
I look forward to your experiences and professional assessments!
kieran
3 Jun 2023 08:04
Genevieve schrieb:
I am also wondering how the moisture regulation inside the cabinet changes.
This is a point that is often overlooked. Wooden back panels absorb a small amount of moisture and release it again, which helps to regulate the cabinet’s internal climate to some extent.
Glass is completely impermeable, so condensation can form, especially if the cabinet is located in more humid environments. This increases the risk of mold or odors on valuable or sensitive contents.
For this reason, I would recommend a glass back panel only in well-ventilated rooms or with targeted ventilation behind the panel. Accordingly, it makes sense to choose glass that is as heat-resistant and scratch-resistant as possible.
Elodie
3 Jun 2023 10:36
I find it fascinating how many technical aspects have already been mentioned here, but you can also look at it from an aesthetic perspective: a glass back panel can really enhance the Pax wardrobe and make it appear lighter. However, I see the main challenge in the installation process.
That said, if done correctly, you can even incorporate cool lighting effects that strongly support a modern look.
Perhaps a semi-transparent version is better, as it gives the desired look without creating a “bare” feeling. This also helps make dust and fingerprints less noticeable.
Elias
4 Jun 2023 09:11
I find this topic very interesting because I have also thought about how to make furniture more customizable.
Joshbe schrieb:
Professional framing or mounting solutions, preferably with rubberized holders
That sounds reasonable – I would be concerned that the glass could be overstressed without a proper frame.
Overall, I think the project is feasible, but only with the necessary expertise or assistance. Otherwise, it could quickly become dangerous or costly.
Ludeo0
4 Jun 2023 11:42
Thank you for the many constructive and detailed contributions!
I find the comments about stability and moisture issues particularly interesting – I hadn’t considered that before.
I am now leaning more towards having a frame-based glass solution made and additionally reinforcing the cabinet with extra braces.
What I am still uncertain about is whether special seals should be applied to protect the edge between the glass and the frame from dust and moisture. Does anyone have experience or tips on the best way to handle this?
