ᐅ Ikea Metod kitchen cabinets: flexible modification and expansion to suit individual needs
Created on: 26 Apr 2021 17:23
rontu
Hello everyone, I am planning my kitchen using the IKEA Metod kitchen cabinets and want to remain especially flexible, as my needs will likely change in the near future. Does anyone have experience with how to cleverly modify and expand Metod kitchen cabinets to adapt them individually to changing requirements? I am particularly interested in practical tips on which modules and system components work well together, how to easily expand or rearrange the cabinets, and whether it might be worthwhile to use special additions like interior drawers, inserts, or extra shelves. Thanks in advance for your advice and exchange of ideas!
Rensan3
27 Apr 2021 15:04
Genevieve is right; there are limits to load capacity.
I would recommend using the base area of the cabinets for heavy loads and installing robust drawer slides there.
Flexibility is great, but stability must always be the priority.
barda6
27 Apr 2021 16:37
The tall cabinets from Metod are especially suitable for expansion. You can flexibly use shelves, drawers, or interior compartments in them.
Assembly goes quickly if you follow the instructions carefully.
sonplo
28 Apr 2021 09:56
An important tip for remodeling and extensions: use the Metod rail profiles on the walls. This allows additional modules to be easily mounted and repositioned as needed.
Make sure to pay attention to the correct alignment and use of leveling feet to keep the structure stable.
Soft-close interior drawers help protect the materials and make handling more comfortable.
rontu
28 Apr 2021 11:29
Thank you for all the information so far! I am still curious about your experience with the compatibility of the Metod modules with the pharmacy cabinets or pull-out cabinets from the same series. Can these be easily combined and expanded later on, or are there limitations that need to be planned for in advance?
Blavin
28 Apr 2021 13:11
The pull-out cabinets are generally compatible with the Metod base units, as they share the same frame dimensions and mounting points.
rontu schrieb:
What has been your experience with the compatibility of the Metod modules with the pull-out cabinets or drawer units from the same series?
It is important to adjust the correct width and height to achieve a continuous front. The mechanism differs slightly, so any later modification should be carefully planned, especially when it involves internal paneling.
In general, you can flexibly combine both within one kitchen area if the dimensions match. The expandability remains intact as long as the connection systems are used carefully.
