á IKEA METOD: How Can I Optimize Storage Spaces with Interior Accessories?
Created on: 9 Nov 2019 14:37
goarianeHello everyone, I am currently planning to redesign my kitchen using the IKEA METOD system and want to optimize my storage space as much as possible â especially through the right interior fittings. I have already chosen the basic units but am unsure how to efficiently organize the inside to store pans, pots, groceries, and small items in a clear and space-saving way.
I am particularly interested in which interior fittings have proven effective for making use of every centimeter (0.4 inches), such as drawers with dividers, lazy Susans, cutlery trays, or shelving systems.
Does anyone have tips on how to customize the system to the available storage so that everything can be found quickly and nothing lies unused inside the cabinet? Also, any advice on what to look for when purchasing so the interior fittings are truly practical and not just visually appealing would be appreciated.
Thanks in advance for your help!
Hello goariane,
When optimizing storage spaces with IKEA METOD, I recommend first measuring the available space precisely and planning the interior fittings based on the usage profile (i.e., what and how often you use certain items).
Some proven elements that many users have found practical:
- Full-extension drawers with integrated pot and pan dividers to improve cleanliness and organization.
- Modular, expandable cutlery trays that consistently save space.
- Lazy Susans are especially suitable for corner cabinets to make the most of otherwise unused corners.
- Shelving systems with adjustable shelves for pantry items, allowing flexible height adjustments.
It is important to consider the load capacity of the drawers, especially for heavy pots. IKEA provides the maximum load for most interior fittings. I also recommend, if possible, choosing interior fittings that match the cabinet fronts and units in material and color â this facilitates future additions and creates a visually harmonious appearance.
In summary: Inventory + a sensible combination of drawer organization + flexible accessories + corner solutions = maximum space utilization.
BEMAU schrieb:
Lazy Susans are especially suitable for corner cabinets to make the most of unused corner space.Exactly, I installed them in my kitchen as well. Here are some additional insights from my experience:
- I recommend combining Lazy Susans with pull-out drawers of varying heights. This way, you can store smaller cooking utensils in shallow drawers and larger pots in deeper ones.
- The IKEA METOD interior fittings include very practical inserts for cutlery and kitchen tools that can be customized to your needs.
- For pantry storage, I find removable baskets convenient, as they can be easily taken out and cleaned.
When planning, it is always important to consider your workflowâitems you use often should be stored nearby and be easily accessible.
If you have any questions about specific products, Iâm happy to help!
Hello goariane,
I would like to share a brief mini-tutorial on how I optimally organized my METOD kitchen system with interior accessories. Maybe it will help you design your storage space.
Step 1: Analyze and categorize your kitchen utensils
- Divide everything into categories: pans/pots, cutlery, pantry items, small appliances, cleaning, mixing tools.
Step 2: Choose cabinet types and interior fittings
- For pots/pans: deep drawers with adjustable dividers, which prevent tipping and make it easier to pull out individual items.
- Cutlery: drawers with cutlery trays, as these modular inserts do not waste much space and keep everything well organized.
- Pantry items: use adjustable inserts and shelves to store jars and cans in neat rows.
Step 3: Use special fittings
- Corner solution: a rotating carousel or magic corner, where high-quality models are recommended for smooth operation and good capacity.
- Inner drawers: very useful for storing smaller utensils that tend to get lost otherwise.
Common mistakes:
- Too many small compartments often create disorder, so itâs better to choose larger units that are multifunctional.
- Placing heavy items in cabinets that are too high becomes impractical.
Finally â always plan a small reserve when ordering, since additional parts are sometimes needed for retrofitting.
Common mistakes:
REPITAR schrieb:
Corner solution: carousel corner unit or Magic-Corner; here, high-quality models that operate smoothly and are easy to load are recommended.I would like to add my agreement to this and provide some technical tips:
The interior fittings for METOD offer several damping system options that significantly improve user comfort. Especially for heavy drawers containing dishes or pots, a soft-close mechanism is worth considering as it prevents slamming and extends the productâs lifespan.
You should also pay attention to the maximum load capacity of each interior fitting. METOD frame cabinets often have a load limit on the drawer slides of 20â30 kg (44â66 lbs), but this varies depending on the model.
Equally important is the depth of the drawers: with a depth of about 60 cm (24 inches), you need to ensure the drawers remain easily accessible and not too deep, otherwise you quickly reach the limit of what can be comfortably reached.
My recommendation for an ideal interior setup:
- Use internal drawers with adjustable metal dividers for pots and pans
- Use internal drawers with half-height boxes (e.g., wire baskets) for food storage
- Add shallow drawers with cutlery trays that feature flexible inserts
- Strategically install interior lighting if the kitchen tends to be dark, as good visibility helps maintain order
What dimensions or configurations have you planned? For a more precise recommendation, that information would be helpful.
