ᐅ Ikea Metod: How can I clean matte cabinet fronts without damaging the surface?
Created on: 21 Dec 2021 08:47
Kinolaf
Kinolaf
21 Dec 2021 08:47
Hello everyone, I have a question regarding the cleaning of my IKEA Metod kitchen with matte fronts. I would like to clean these surfaces gently to avoid any damage such as dull or shiny spots. Which cleaning products and methods are best suited to maintain the matte finish without harming it? I have heard various suggestions, ranging from mild dish soap solutions to specialized plastic cleaners, but it is important to me that the material texture is not affected. Are there any experiences or recommendations on how to clean the matte fronts optimally without causing unsightly stains or an unwanted glossy effect? Thanks in advance!
Kurtis5
21 Dec 2021 09:23
I would recommend cleaning the matte fronts only with a damp microfiber cloth and mild dish soap. Do not use abrasive cleaners or harsh chemicals. After cleaning, wipe again with clear water and dry.
Laurence
21 Dec 2021 11:10
Hello Kinolaf, your question is very precise regarding the gentle cleaning of matte fronts – this is important because these surfaces are sensitive to overly aggressive cleaning. Generally, I recommend always using mild cleaning agents without alcohol or abrasive particles. A neutral all-purpose cleaner or a dishwashing solution in lukewarm water is ideal. It is important to use a soft cloth, preferably a microfiber cloth, to avoid scratching the surface. Afterward, you should immediately wipe the fronts with a clean, dry cloth to prevent water spots. It is also advisable to test cleaning products on an inconspicuous area if you want to use specific products. Some users report that silicone-free plastic care products reduce stains, but caution is advised as some products can alter the matte appearance. If you would like to know more about caring for the surface after cleaning, I can gladly provide further tips!
pauPierce
22 Dec 2021 14:37
Kinolaf schrieb:
Which cleaning agents and methods are best suited to maintain the matte surface without damaging it?
A good question that I’d like to answer in detail, as matte cabinet fronts are often treated improperly. The Metod fronts from IKEA are usually made of melamine-coated engineered wood or similar composite materials with a matte finish. The surface is sensitive to alcohols, solvents, or harsh cleaning agents.
For cleaning, I recommend the following steps:
- Use lukewarm water with a few drops of mild, pH-neutral dish soap.
- Use a clean, soft microfiber cloth that is only slightly dampened.
- Wipe the fronts in gentle, circular motions without applying pressure.
- Avoid abrasive cleaners, scouring pads, or paper towels, as these can scratch the surface.
- After cleaning, immediately wipe down with a dry, lint-free cloth to prevent water spots.
If you have tougher stains that cannot be removed with this method, you can carefully use specialized plastic cleaners, but be sure to test first in an inconspicuous area. Also, do not use wax or oil treatments, as these can make matte surfaces shiny.
May I ask if you have already tried specific cleaning products and what kind of stains you want to remove? That way, I can provide more targeted advice.
Danial
23 Dec 2021 10:18
Laurence schrieb:
It is also advisable to test cleaning agents in an inconspicuous area
I agree with that, but we should add a critical question: Why do we actually trust the standard cleaning recommendations when even IKEA often provides only vague guidelines on their websites?
Could it be that many users unintentionally damage the matte surface through incorrect cleaning because truly important factors like cleaner pH, micro-scratches, or mechanical stress are underestimated?
I encourage all users to conduct their own tests with various cleaning methods and document the changes, for example, whether a certain method alters the appearance in the long term. Only in this way can we reliably determine which products are genuinely safe to use.
At least, in my personal experience with my Metod kitchen, using a standard window cleaner led to a matte spot that noticeably shined, indicating possible micro-scratches or a reaction with solvents.
