ᐅ Ikea METOD: How can I build space-saving cabinets with sliding doors?
Created on: 4 Dec 2021 08:17
Tonasi
Tonasi
4 Dec 2021 08:17
Hello everyone, I am currently planning to install new METOD cabinets from Ikea in my kitchen and want to use sliding doors to make the best use of the available space. Specifically, I am interested in how to build Ikea METOD cabinets with sliding doors in the most space-saving way without sacrificing functionality. Are there any special installation tips or mechanisms that work particularly well for tight kitchen spaces or narrow hallways? If anyone has experience with different types of sliding doors, I would like to know how they perform in everyday use and what to consider during installation, especially regarding integration with existing METOD components. Thanks in advance for your advice!
TEOZAR
4 Dec 2021 09:02
Hello Tonasi, your concern is very practical. Sliding doors for Ikea METOD kitchens are generally well suited for space-saving kitchen projects. An important point to consider is the precise choice of the sliding door mechanism. Ikea offers its own sliding doors for METOD, which can be installed either as overlay doors or using rail systems.
- It is recommended to mount the sliding doors on the cabinet fronts rather than inside the cabinet depth: this way, the internal cabinet depth is maximized.
- For particularly narrow rooms, you can also use overlapping sliding doors with Ikea’s system to maximize cabinet access.
Additionally, correct alignment and secure fastening on the top and bottom rails is crucial to ensure smooth sliding function.
If your space is very narrow, precise measuring to select the appropriate rail length is worthwhile, as this can save space.
pilous
4 Dec 2021 09:45
Interesting start, Tonasi. However, I wonder if sliding doors for METOD are really the most space-saving solution.
TEOZAR schrieb:
Ikea offers its own sliding doors for METOD, which you can install either as surface-mounted or using a track system.
That sounds reasonable, but you have to consider that the tracks and mechanisms themselves take up some width. This reduces storage space again. For those who really need to watch every centimeter (inch), this might actually be counterproductive.
In very tight kitchens, I would consider completely different door solutions, such as folding doors or even rollable systems that run in front of the cabinet to avoid affecting the interior space.
Does anyone have experience comparing these systems? It would be interesting to get data on the actual space gain or loss.
KAMERON
4 Dec 2021 10:12
From a technical and space-saving perspective, sliding doors are a practical alternative to traditional hinged doors for METOD as long as the following aspects are considered:
- Selecting the sliding door size: Only the officially offered dimensions by Ikea ensure smooth operation and a perfect fit.
- The track system requires about 3 to 5 cm (1 to 2 inches) of space within the cabinet frame and at the front, which cannot be used for storage.
- The advantage is that sliding doors do not need space to open outward, which is crucial in tight room conditions.
Therefore, you should first carefully measure the usable space and the required cabinet depth, then weigh the slight space loss caused by the tracks against the space gained in front of the cabinet before deciding on sliding doors.
Sinan-meo
4 Dec 2021 12:04
I would like to add that when building METOD cabinets with sliding doors, it is advisable to keep the following points in mind:
- Use the continuous tracks above and below the cabinet whenever possible to ensure stable guidance.
- Make sure the doors are installed precisely to prevent them from sticking or scraping.
- Proper alignment is also very important, especially in rooms with slightly uneven floors or walls. In such cases, adjustments using shims or adjustable feet may be necessary.
Additionally, I recommend monitoring the maximum load capacity of the doors – depending on the size of the fronts, the requirements for the sliding tracks change, which can affect durability.
pilous
5 Dec 2021 15:23
I would like to revisit this topic from a different perspective:
KAMERON schrieb:
The sliding rails require about 3 to 5 cm (1 to 2 inches) of space inside the cabinet frame and at the front, which cannot be used for storage.
This point is crucial for me. If someone buys METOD cabinets as a base due to cost reasons, they should be aware that sliding doors always reduce the interior space. Especially in kitchens, where cabinet depth is often limited (usually around 60 cm (24 inches)), those 3-5 cm (1 to 2 inches) needed for the rails can make the difference between practically usable and restricted shelf space.
Tonasi schrieb:
How can I build Ikea METOD cabinets with sliding doors in the most space-saving way without sacrificing functionality?
My recommendation: Before installing sliding doors in the METOD system, carefully calculate the interior space requirements relative to the door mechanism and consider whether hinged doors with clip fittings or even cabinets with drawers might be a more practical alternative.
