ᐅ Ikea Besta – how can I effectively remove deposits and dust from the inside?
Created on: 11 Aug 2021 19:23
pietubeHello everyone, I am using an Ikea Besta sideboard that I would like to clean thoroughly, especially on the inside, where dust deposits and occasional moisture have unfortunately accumulated over time. I am interested in methods or products that effectively remove these deposits without damaging the surfaces or materials inside. Are there any proven cleaning techniques that work well, even in hard-to-reach corners and joints? I mainly use this piece of furniture to store media and want to avoid moisture or cleaning agents damaging the interior. I would appreciate any tips on cleaning products, tools, or procedures.
pietube schrieb:
I am interested in which methods or products can effectively remove these deposits without damaging the surfaces or materials inside.For effective removal of dust and deposits inside an Ikea Besta unit, a multi-step approach is recommended:
- First, thoroughly vacuum the interior walls and corners using a soft microfiber cloth or a vacuum cleaner with a brush attachment to remove loose dust.
- For more stubborn deposits, a mixture of lukewarm water and a few drops of mild dish soap works well. Apply this lightly with a damp (not too wet) sponge or cloth and gently wipe the surfaces.
- Afterwards, wipe again with a dry cloth to avoid leaving moisture on the material.
- Avoid using harsh cleaners or abrasive pads, as these can damage melamine or acrylic surfaces.
For hard-to-reach corners, a small soft-bristled brush, such as a paintbrush, is useful to sweep dust out of crevices. The general aim is to keep moisture low and prevent mechanical damage.
Additionally, I recommend cleaning the furniture regularly to prevent dust buildup in the first place, which helps preserve both the material and overall appearance over time.
SUBEN60 schrieb:
For hard-to-reach corners, a small brush with soft bristles works well, such as a paintbrush, which can effectively sweep dust out of cracks.I can confirm this, especially those corners are really tricky when dirt has been left unattended for a while. I also had moisture stains inside, probably due to the indoor humidity. Besides cleaning with mild soapy water, using a dehumidifier in the room helped me back then to prevent further moisture buildup.
What was also important to me: I regularly ventilated the room afterwards and made sure the sideboard was not placed too close to exterior walls, which are often cooler. Otherwise, cleaning alone doesn’t achieve much if the underlying causes aren’t addressed.
So I can really only recommend checking the indoor climate conditions after cleaning to prevent dust and moisture issues in the long run.
pietube schrieb:
I mainly use this piece of furniture for storing media and want to avoid moisture or cleaning agents damaging the interior.Honestly, I think the problem often isn’t the cleaning itself but the general storage conditions. Media sideboards are naturally prone to dust and moisture, especially if the doors are left open or the rooms aren’t properly ventilated.
I’m a bit skeptical whether the usual “gentle” cleaning methods are effective in the long term. Why not completely empty the interior and wipe it down with 70% isopropyl alcohol? It dries quickly, removes grease, and prevents mold without damaging the material—provided it’s applied evenly.
Using a vacuum cleaner plus water and dish soap seems more cosmetic to me; that feels too mild. For truly clean conditions, sometimes a more thorough approach is necessary. Just a thought!
