ᐅ How much weight can the IKEA Metod drawers support?
Created on: 15 Feb 2020 18:47
segustav
segustav
15 Feb 2020 18:47
I have a pretty specific question for those who are familiar with IKEA Metod drawers or who have used them extensively:
How much weight can the individual Metod drawers actually hold without causing damage or showing early signs of wear?
I’m not only interested in the official maximum weight specified by IKEA but especially in practical everyday experience—so how much can you realistically put inside before stability or functionality start to suffer.
It would also be helpful if someone could point out the differences between various types of Metod drawers (e.g., wooden versus metal-sided) and how that affects their load capacity.
My goal is to plan a kitchen solution that is as sturdy and durable as possible, allowing me to store heavier pots or appliances in the drawers.
Thanks in advance for any helpful tips and specific information!
V
vinpau
15 Feb 2020 19:52
Great question, segustav! 😊
I installed Metod drawers in my kitchen almost a year ago and can say: these units really hold up well! 😎
Based on my experience, you can easily expect around 15 to 20 kilograms (33 to 44 pounds) per drawer without any wobbling or squeaking. My deeper drawers even carry more weight since I often store heavy pots and containers there – everything stays securely in place!
A quick tip: always use the full installation width of the drawers, so the weight is better distributed. Also, make sure the drawers are properly installed; that makes a huge difference.
If you want to know more, just ask—I’m happy to help! You can build some really cool modules with Metod! 👍
fugolo
16 Feb 2020 08:34
segustav schrieb:
How much weight can the individual Metod drawers actually hold without causing damage or early signs of wear?
Hello segustav,
Regarding the exact load capacity of IKEA Metod drawers, here is what can be said:
- According to IKEA specifications, the maximum load on the drawer runners is usually around 25 kilograms (55 pounds).
- However, this applies to standard drawer fronts and specific drawer depths; variations in material and design can affect the result.
- Drawers with metal sides tend to be more durable, while the classic wooden side panels are more prone to wear under heavy load.
Based on my own experience and various user reports, it is recommended to limit the maximum weight to about 15 to 20 kilograms (33 to 44 pounds). This ensures greater longevity and reduces the risk of misaligned runners or sagging bottoms.
Additionally, I recommend distributing the load as evenly as possible. Uneven weight can lead to faster damage, especially with heavy pots or appliances.
Deep drawers (e.g., 60 cm [24 inches]) can typically accommodate around 20 kilograms (44 pounds) when the weight is spread evenly across the entire drawer base.
A common mistake is overfilling Metod drawers and concentrating weight in one spot. This should be avoided.
In summary:
- Practical max load: 15–20 kg (33–44 lbs)
- Even weight distribution
- Prefer metal sides for higher stability
I hope this information helps you with planning your kitchen!
plo60
16 Feb 2020 11:19
vinpau schrieb:
Based on my experience, you can safely estimate about 15 to 20 kilograms per drawer
I would like to add a caution that while these practical values are useful, it is important to understand the basis on which they are derived.
IKEA itself typically states 15 kg (33 lbs) as the official load limit for the METOD drawers, which is mainly due to the technical constraints of the slides and fittings.
fugolo schrieb:
Drawers with metal sides tend to be more durable, whereas the classic wood side panels are more prone to wear under heavy loads.
I agree and would add that the type of installation also plays a major role: if drawers are installed incorrectly or lack intermediate reinforcements, their load capacity can decrease significantly.
It is equally important to consider dynamic loads—for example, when a drawer is suddenly pulled out and heavy contents shift, the effective weight can momentarily be higher.
My advice: if you plan to store very heavy items, consider investing in reinforced systems or additional inserts to prevent damage. In my opinion, the 15 kg (33 lbs) limit is a good guideline to stay on the safe side.
