ᐅ What is the best way to clean the glass fronts on Pax units?
Created on: 24 Feb 2022 08:17
peomu56
peomu56
24 Feb 2022 08:17
I have a question about caring for my Pax wardrobe doors with glass panels. Specifically, I’m interested in the best way to clean Pax glass fronts without leaving streaks or causing any damage. I’ve read that some types of glass can be sensitive to certain cleaning products, so I want to be on the safe side.
I’m curious about which cleaning products—whether special glass cleaners, vinegar solutions, or perhaps water with a mild dish soap—are best suited to thoroughly clean the glass surfaces while avoiding scratches and streaks.
Are there also any tips on how to apply the cleaner, drying techniques, or if microfiber cloths might be recommended?
I’d really appreciate your experiences and advice, especially from those who have been cleaning Pax glass fronts for a while.
fikeo
24 Feb 2022 08:53
Hello peomu56,
First of all, thank you for your detailed and well-formulated question. Cleaning the glass fronts of Pax furniture is indeed a topic where things often go wrong, mainly due to improper cleaning products or techniques.
I generally recommend initially wiping the glass fronts with clear water and a soft cloth to remove coarse dust and dirt. After that, a pH-neutral glass cleaner or a homemade solution of lukewarm water with a few drops of mild dish soap works very well.
It is important not to use abrasive cleaners or microfiber cloths with a rough texture, as these can cause tiny scratches that make the glass look dull.
For drying, lint-free cloths are best, ideally special window leather cloths. If you use a microfiber cloth, choose one designed specifically for glass and not too rough.
Another tip: never spray directly onto the glass. Instead, spray onto the cloth first to avoid drips that could cause damage elsewhere.
I hope this helps you!
Luchen
24 Feb 2022 09:14
For glass at Pax, it is best to wipe with a damp microfiber cloth. For heavier dirt, apply a small amount of glass cleaner to the cloth. Always rub gently; do not use abrasive sponges or paper towels.
faso31
24 Feb 2022 11:48
fikeo schrieb:
I generally recommend first wiping the glass fronts with clear water and a soft cloth to remove coarse dust and dirt.
I agree, but I would like to point out that the term "soft cloth" is often too vague. What type of fabric should be preferred? Microfiber cloths come in various qualities. It certainly makes sense to use a cloth with the finest possible fiber structure to avoid scratches.
Furthermore, I am interested to know if anyone has experience with vinegar-water mixtures, as they are environmentally friendly but can cause damage to certain types of glass. So, who can share reliable long-term experience here?
I also want to question the claim that you should never spray directly onto the glass. From my perspective, this greatly depends on the situation – if you are careful, it should not be a problem. Proper application and dosage would definitely be important here.
bulanau
25 Feb 2022 15:29
A structured guide for cleaning Pax glass fronts:
- Preparation: First, remove dust and coarse dirt using a soft, clean microfiber cloth or a duster.
- Cleaning solution: Use lukewarm water mixed with a few drops of mild dish soap or a pH-neutral glass cleaner. Vinegar-based solutions should generally be avoided on glass panels, as they can damage the seals.
- Application: Dip the microfiber cloth into the solution, wring it out well to avoid excess moisture, and gently wipe the glass surfaces.
- Drying: Blot or wipe the glass surfaces with a lint-free, dry microfiber cloth to prevent streaks.
- Additional tip: Avoid using paper towels or abrasive sponges, as these can cause scratches.
By following these steps systematically, the glass fronts will remain clear and undamaged.
sarla
26 Feb 2022 10:03
faso31 schrieb:
I would also be interested to know if anyone has experience with vinegar-water mixtures, as these can be environmentally friendly but may cause damage to certain types of glass.
Vinegar is often promoted as an environmentally friendly alternative, but I would advise against using it on painted or specially coated glass surfaces, like those found in Pax units. Vinegar is acidic and can damage seals or coatings, potentially causing long-term harm.
Instead, I recommend pH-neutral cleaners specifically designed for glass or sensitive surfaces. This approach is better supported by scientific evidence and helps protect the materials over time.
Using plain water with a mild dish soap, as mentioned earlier, is usually enough for regular cleaning. For tougher smudges, alcohol-free glass cleaners can be effective without the risk of damage.
