ᐅ How can small scratches on a PAX wardrobe be repaired?
Created on: 8 Dec 2020 09:17
maxpo
maxpo
8 Dec 2020 09:17
Hello everyone, I have a PAX wardrobe from IKEA that unfortunately has developed some small scratches on the white foil surface. Since this is quite noticeable visually, I am looking for a reliable method to repair or at least reduce the appearance of these small scratches as discreetly as possible. I want to avoid reapplying the entire surface film or replacing it completely.
Has anyone had experience with a specific technique or products that work well on PAX wardrobes? Are there any practical tips or easy-to-use repair solutions you would recommend? It is also important to me that the solution is durable and does not cause further damage. Thanks in advance for your feedback!
tinau
8 Dec 2020 09:45
The best option is a wax stick in the appropriate color, applied in several thin layers and then carefully polished. This method usually hides small scratches effectively.
blapau
8 Dec 2020 10:12
Basically, it is important to note that the PAX wardrobes have a laminated surface and are not painted. Therefore, repairs should be carried out carefully to avoid further damaging the laminate. Wax sticks or special furniture repair kits designed for laminated surfaces usually work best. It is essential to clean and dust the area beforehand to ensure the repair adheres properly.
bente
8 Dec 2020 11:05
blapau schrieb:
It is important to clean and dust the area beforehand to ensure the repair adheres properly.
That makes sense, because I remember how many small scratches my cabinet had and how impatiently I just smeared paint or something similar on it – which unfortunately didn’t really help. I can understand how much these kinds of scratches can bother you, especially if you care about maintaining a well-kept home. So my advice would be: be patient during the preparation and use the right products!
ronti
8 Dec 2020 12:22
In short: Use color-matched furniture markers, apply them thinly, and immediately wipe off any excess. Then, gently buff with a soft cloth.
SUDAN
8 Dec 2020 13:57
A brief guide for repairing small scratches on PAX cabinets:
- First, clean the damaged area with a mild cleaning agent and a lint-free cloth.
- Examine the scratches carefully: Are they superficial or deeper? For superficial scratches, polishing with furniture polish is often sufficient.
- For deeper scratches, wax sticks or repair kits matched to the color of the PAX surfaces are suitable.
- Apply the wax stick sparingly, immediately removing any excess material with a soft cloth.
- Finally, polish with a microfiber cloth to restore shine and uniformity.
Common mistakes include applying too much material or using overly aggressive cleaners that can damage the laminate. This way, the repair remains durable and visually appealing.
