ᐅ How do you install sliding doors on an Ikea PAX wardrobe?
Created on: 21 Feb 2022 09:13
karflo54
Hello everyone, I am currently facing the task of installing sliding doors on an Ikea Pax wardrobe and could use some support. Although the Ikea instructions are included, I find them somewhat insufficient in certain areas, especially regarding the precise attachment of the running rails and how to best adjust the doors so they close cleanly and flush.
Could someone please explain in detail how to properly install the sliding doors, what to pay attention to, and if there are any specific tips or tools that make the installation and adjustment easier and more precise? What is a sensible order of steps, and are there common mistakes I should avoid?
I would appreciate as detailed guidance as possible, as I want to do this properly.
Rensan3
22 Feb 2022 12:22
Make sure not to overtighten the screws on the adjustment rollers. Otherwise, the door will lose its alignment and wobble. The optimal resistance should be noticeable without the door sticking.
karflo54
22 Feb 2022 13:19
Rensan3 schrieb:
Make sure not to overtighten the screws on the adjustment wheels.
Thank you, that was my concern as well. I tightened the screws very firmly on the first attempt, but after reading your comments, I loosened them a bit, and now it runs much more smoothly. The balance between grip and mobility is really important.
The overall result looks much cleaner now, and I'm glad I read your advice.
daalessio
23 Feb 2022 08:46
One last tip: If you have relatively tall doors, it is advisable to check the rails for secure fastening after installation – vibrations and regular use can loosen screws. Tightening them once a year helps protect the materials and maintains consistent operation.
karflo54
23 Feb 2022 09:15
daalessio schrieb:
Tighten once a year to protect the materials and maintain smooth operation.
Perfect, thanks! I hadn’t considered regular maintenance before, but it makes sense. Now I have a good basis to professionally install my Pax sliding doors and maintain them in the long term.
