ᐅ Kallax screws stripped – possible replacement solutions?
Created on: 5 Feb 2024 08:24
Mathew2
I am facing a rather annoying problem with my IKEA Kallax shelf. Several of the connection screws that hold the shelf together have stripped heads, so I can no longer unscrew them. The shelf is supposed to remain stable, but without these screws, that is of course difficult.
My question: Are there any tried-and-true methods to replace or remove such stripped Kallax screws without damaging the furniture? I am specifically asking about replacement solutions because some IKEA spare parts are not easily available, and there are many different types of screws used.
Has anyone had similar issues, maybe with tips on alternative types of screws or tools that could help? Should the whole shelf be reassembled differently, or are there special threaded inserts that would fit?
I look forward to your suggestions and thank you in advance!
lyndon
6 Feb 2024 07:51
One point I would like to add: If you need to completely drill out the screws, I recommend using a suitable tap afterward to restore the internal thread. This significantly improves the durability of the connection compared to using standard wood screws.
If you don't have the necessary tools, visiting a well-stocked specialist store might help, where you can possibly have the replacement parts adjusted on site.
As already mentioned, choosing the right size and material is essential when purchasing replacement screws.
blapau
6 Feb 2024 09:40
I agree with the previous recommendations and would like to add that with IKEA furniture, it sometimes makes sense to buy the complete set of connectors for a few extra dollars if the assembled shelf is still in good condition.
However, if you value long-term stability, metal threaded inserts (such as helicoils or similar) are a reliable solution. They are not too difficult to install and provide a really strong hold.
Just be careful not to overtighten in the plywood or particle board – less is often more.
narDietmar
6 Feb 2024 10:13
GiRoyce schrieb:
Thread inserts (Helicoils) are a good alternative
I want to emphasize this. Often underestimated, but investing in thread inserts saves a lot of trouble in the long run because you no longer stress the shelving components with untreated wood threads.
You can also get the right tool set (drill bits, taps, insertion tool) fairly cheaply with some patience – it’s worth it if you repair or assemble furniture frequently.
KIN42
7 Feb 2024 09:55
I tried a slightly different method that worked quite well: If the screw head is stripped and no tool can grip it anymore, I carefully drill a small notch on the side of the screw with an appropriate round drill bit, then use a mini Phillips screwdriver or a small flathead screwdriver to gently turn it out.
It doesn’t always work, but for smaller screws on the Kallax shelf, this method has helped me. Afterwards, carefully screw in new screws – it usually works.
It’s worth trying before using a screw extractor / easy-out, as it can be gentler.
GiRoyce
7 Feb 2024 11:02
KIN42 schrieb:
I carefully drill a small notch on the side of the screw with an appropriately sized round drill bit and then use a mini Phillips screwdriver or a small flathead screwdriver to gently unscrew it.
Good example of practical creativity! 🙂
Just a note: There is a risk of damaging the surrounding material if you drill too deep. But if you do it cleanly, it often works well.
Thanks for sharing the idea!
SETHBLA
7 Feb 2024 16:18
dijan schrieb:
Buy a locking plier, a left-handed screw extractor, and new screws.
Usually, that’s all you really need. Sometimes people make it more complicated than necessary. Just the right tools, patience, and the correct replacement screws – and you’re done 🙂
