ᐅ Is it possible to assemble Ikea BESTA without the original screws without compromising stability?
Created on: 17 Sep 2023 08:17
Rolfbar
I have the following problem: I want to assemble an Ikea Besta piece of furniture, but unfortunately, I no longer have any of the original screws. My specific question is: Is it possible to build the BESTA system without the original screws without noticeably compromising the stability and load-bearing capacity of the furniture? I am especially interested in practical experience and recommendations regarding alternative fastening materials or techniques that are compatible with the construction of the BESTA components.
Thanks in advance for your opinions!
Rolfbar
18 Sep 2023 07:52
GALEO4 schrieb:
I dare say that if you do not replicate the exact same properties of screws and wall plugs 100%, you will definitely lose stability.
That makes sense to me, but how exactly do different screw properties affect stability? Can a slightly different length or varying material hardness really have noticeable effects on the structural integrity and usability of the piece of furniture? And what about the risk of wood cracks or the anchors pulling out of the drilled holes?
If anyone has concrete experience or mechanical explanations regarding this, that would be extremely helpful!
Deandre
18 Sep 2023 09:14
Yes, it can have an impact. If a screw is too long, it might press into the material, causing stress or damaging the components. If it’s too short, it won’t provide enough holding strength. The hardness and material quality affect how well the screw transfers loads and whether it loosens over time. The thread pitch also matters, as the wrong pitch can make tightening difficult or damage the receiving material.
Regarding wood: if the screw is too thick or too hard, it can cause cracks. On the other hand, screws made from material that’s too soft may fail as fasteners. That’s why it’s important to choose replacements with specifications as close as possible to the originals.
Timofa
18 Sep 2023 10:08
Rolfbar schrieb:
And what about the risk of cracks forming in the wood or the holes tearing out?
Exactly! I would recommend gathering all parts and screws before the final assembly and doing some test drilling and screwing on scrap wood. This way, you can ensure the screws fit without damaging the wood. And: Always tighten carefully, don’t overtighten! This not only keeps everything stable but also looks better in the end 😊
BOLUKEO
18 Sep 2023 11:23
Use replacement screws with the same diameter and appropriate length. Make sure they are of good quality, as this is sufficient for stability. Otherwise, the assembly may go wrong.
Santi
19 Sep 2023 08:36
The furniture remains stable when screws and dowels are replaced accurately. Pay attention to the correct fit and material. Simple replacements without precise sizing cause problems.
Luchen
19 Sep 2023 09:10
Just a note: Original screws are often galvanized. Stainless steel replacements can corrode, but last longer. Important for durability.
