ᐅ BILLY shelf special screws for increased load capacity?
Created on: 20 Apr 2020 14:07
duwoodrow
I am currently looking into a specific question regarding the IKEA Billy bookshelf: Are there any special screws or fasteners that should be used for increased load on the shelf, instead of the standard screws included in the basic package?
Specifically, I want to load the shelf more heavily (e.g., with more books or heavy decorative items) and wonder whether the original mounting hardware can withstand the increased stress over time or if it is advisable to use reinforced screws, wall plugs, or other connectors.
My question concerns not only the wall fixing but also all the screws that connect the individual shelf components – for example, the fastenings for the back panel, side panels, or shelf supports.
Does anyone have experience or recommendations for special screws that can significantly improve the stability of the BILLY bookshelf?
Thanks in advance for your answers.
LuMarcel43
21 Apr 2020 09:45
duwoodrow schrieb:
I’m wondering if it’s theoretically possible to switch to metric screws—for example, instead of the IKEA standard Spax screws with a 3.5 mm diameter, use 5 mm screws with matching threads and nuts.
In theory, yes, but you need to consider the wood. A larger pilot hole is required, which weakens the material.
My suggestion: with solid wood (spruce, pine), it can work well; with particleboard, it’s more problematic.
Also, the wood’s strength must be able to handle the thicker screw, otherwise the load transfers to the wood rather than the joint.
So: yes, it can work, but it carries risks. Consider switching the screws during assembly rather than retrofitting them later.
Nadine
21 Apr 2020 10:12
Hello!
Switching to metric screws can indeed be a good idea if they have a larger diameter and are made from a durable material.
It is important, as mentioned before, that the shelf material is not damaged too much. If you plan to simply screw them in to improve the shelf without pre-drilling, there is a high risk of damaging the wood.
My advice: For particleboard, it is better to rely on additional metal brackets and high-quality wall fixing. For solid wood, metric screws with proper pre-drilling are a good solution.
Also, pay attention to the length of the screws so that they securely grip the material without protruding on the other side.
If needed, I can recommend exact dimensions if you let me know which Billy model you have.
meGreg
21 Apr 2020 11:04
duwoodrow schrieb:
Or is there a risk of damaging the wood too much in the process?
You’re absolutely right!
I would recommend always drilling a pilot hole first and then driving in the thicker screws; otherwise, you might damage the shelf.
Also, the screws shouldn’t be oversized, or you’ll end up with cracks – and that’s definitely something you want to avoid.
Doing some tinkering and testing on scrap pieces can really help. That’s how I do it – a bit of trial and error until you get the hang of it 🙂
bente
21 Apr 2020 12:28
Upgrading like this is always a bit of a gamble.
Nadine schrieb:
My tip: When working with particleboard, it's better to use additional metal brackets...
I completely agree. That made all the difference for me.
And don’t hesitate to combine several measures – upgrading screws, adding extra brackets, stronger back panels.
In the end, that makes me feel more secure and leaves me with no worries.
duwoodrow
22 Apr 2020 08:47
Great suggestions here, thanks! Especially the combination of screws and brackets sounds sensible.
I have one last question about wall mounting: Are there any specific screws or anchors you would recommend as "reinforced" for BILLY? I have a drywall (plasterboard) wall, and the standard anchors usually tend to be weak points under load.
So, are there any special screw/anchor combinations for drywall that have proven to be particularly reliable?
Nadine
22 Apr 2020 09:16
For drywall panels, I recommend using special drywall anchors, such as hollow wall anchors with metal expansion or metal clip anchors. These provide significantly better support than simple plastic anchors.
The screws should match the anchor size and be long enough, for example, 6 mm (1/4 inch) thick screws and at least 50 mm (2 inches) long, depending on the wall construction.
Alternatively, there are heavy-duty anchors for drywall that offer even greater security. However, this also depends on the wall’s internal structure (e.g., spacing between studs).
If possible, you should also screw the shelves directly into the drywall studs to transfer the load to the stable frame.
I hope this helps!
