ᐅ IKEA MALM Bed Squeaks Despite Tight Screws – Possible Causes?
Created on: 14 Sep 2023 08:12
MacaradocM
Macaradoc14 Sep 2023 08:12Hello everyone, I have been using the IKEA Malm bed for some time now, but I am annoyed by a constant squeaking, even though all screws and connections are properly tightened.
I am especially interested in knowing: What causes could be responsible for the squeaking despite correct and firm screwing? Are there known weak points with this model or mechanical characteristics that might explain it?
I have tightened all screws according to the recommended torque and checked that no wooden parts move against each other, but the noise remains, especially when turning over or getting up.
Maybe there are people here with similar experiences or technical knowledge who can give me tips on how to diagnose the issue precisely and fix it effectively. Thank you!
Hello Macaradoc, the squeaking despite tight screws could have several causes.
A common reason in wooden beds is slight movement between wood surfaces that are resting against each other but not screwed together, for example where the slatted frame rests or where individual wood panels rub against each other. Slightly swollen wood or changes in humidity can also create tension.
I would recommend carefully checking all contact surfaces for small gaps, unevenness, or missing spacers. Applying felt or rubber padding to the contact areas can also help reduce friction and thus squeaking.
JONSON schrieb:
A common cause in wooden beds is minimal movement between wooden surfaces that are resting against each other but not screwed togetherThis is a good point, but it is also worth considering whether friction alone is the cause.
If the bed creaks even though all screws are reportedly tight, it could be that the pads or materials intended to reduce friction (rubber buffers, plastic washers) are porous or damaged.
Has it been checked whether, for example, the plastic sleeves or washers in the screw connections are still intact and properly seated?
Additional information: It is well known that the MALM bed often allows slight movement at the corner joints between the side panels and the headboard due to its construction. These movements cannot be completely eliminated even when the screws are tightened firmly.
The cause of the squeaking is often the combination of wood-on-wood contact and minimal micro-movements caused by load.
A commonly used solution is to apply assembly paste, graphite powder, or silicone spray to the friction points to reduce the noise.
I can understand how annoying constant squeaking at night can be.
I had the same problem with my MALM bed, even though I tightened everything properly and even replaced the slatted frame. In the end, regularly rubbing wax on the joints helped somewhat.
What also helped me was patience, repeatedly trying small adjustments to gradually identify the cause. A bed is not cheap, so you just want peace and quiet 😉
