ᐅ What to do if Malm screws keep coming loose?
Created on: 18 Oct 2021 08:34
Sarhanne54
I have a specific issue with my Malm furniture (IKEA): the screws that connect the individual parts keep loosening, even though I have tightened them several times. This mainly affects the heavily loaded joints, such as the connections between the side panels and shelves.
I wonder if this is simply due to the type of wood or the quality of the screws, or if I am making a fundamental mistake during assembly. Are there any special tips or tools that can help prevent this constant need for retightening?
I hope someone here has experience and can explain why this happens and how I can fix it reliably—without having to check the screws all the time.
Thanks in advance for your help!
GEKAU51
18 Oct 2021 11:05
Sarhanne54 schrieb:
That makes sense, thanks!
Hmm, I doubt that thread locker is the general solution here. Just wait and see, the simple reason is that IKEA furniture is designed for quick assembly, not for long-term durability under heavy use. The screws are meant to be tightened once, and then the design reaches its limits.
I would say retightening is the price you pay for such inexpensive furniture.
Of course, you can improve things with thread locker, or washers if you like, but that won't fundamentally solve the problem. It’s better to start with sturdier screws or buy small repair kits.
If you want lasting stability, you need to invest elsewhere.
Sarhanne54
18 Oct 2021 11:30
GEKAU51 schrieb:
The need to retighten is the price you pay for such affordable furniture.
Thanks for the honest perspective – even if it’s not exactly what I wanted to hear 🙂
I’m actually looking for more pragmatic solutions, since I’m basically happy with the furniture but don’t want to have to take everything apart and reassemble it every six months.
If I understand correctly, thread locker plus stronger screws with washers should help most people.
Could anyone provide more details about "reinforced connection kits"? Do you mean additional brackets, like metal angle brackets for reinforcement? Or special fabric adhesive pads or something similar?
Dirkmin
18 Oct 2021 13:11
Here is an addition from a technical perspective:
When screws are repeatedly tightened in MDF material, the connections often loosen because the threads strip out in the soft wood structure.
A common solution is to use so-called thread inserts, which are screwed into the wood and provide a metal thread. This significantly increases the connection strength.
Additionally, angle brackets (metal brackets) are a proven method to reduce the load on the screws and thus minimize the problem of loosening screws.
Combined with appropriate thread locking, this results in a stable construction that does not need constant retightening.
flota
18 Oct 2021 13:42
Dirkmin schrieb:
A solution often used is the application of so-called "thread inserts," which are screwed into the wood and provide a metal thread.
That is correct; this works very well.
Additionally, I recommend carefully applying wood glue to the screw holes before driving in the screws and then allowing it to dry briefly.
This reduces wood movement and creates a firmer connection, even if the screws themselves are not fully tightened.
This is especially useful for furniture that is frequently loaded and moved, as can be the case with Malm.
Sarhanne54
19 Oct 2021 08:02
Thank you for all the helpful advice so far,
just one last quick question from my side:
If I want to use these threaded inserts, what is the best way to install them without causing too much trouble? I want to connect the furniture as authentically and securely as possible without having to carry out major modifications.
Or would you rather recommend combining the existing screws with spring washers and thread locker, and using metal brackets as additional reinforcement if needed?
I’m curious if anyone can suggest the perfect balance of “practical, relatively simple, and cost-effective.”
bensau
19 Oct 2021 08:45
Sarhanne54 schrieb:
I’m curious if anyone can recommend the perfect mix of “practical, relatively simple, cost-effective.”
My recommendation:
1. Secure screws with medium-strength thread locker.
2. Use spring washers or lock washers to minimize movement.
3. For heavily loaded areas, consider adding metal brackets for reinforcement.
Thread inserts are great, but if you don’t already have them, installation is a bit more complicated and not quite as cost-effective.
The combination of washer, thread locking, and bracket makes the furniture more durable without having to tinker much with the construction.
And—don’t forget—tighten the screws neither too tight nor too loose!
