ᐅ How can Ikea HEMNES furniture be assembled more securely?
Created on: 3 Jan 2023 08:36
Bueddie
Hello everyone, I would like to start a discussion with the specific question: How can Ikea Hemnes furniture be assembled or modified to significantly improve its stability?
My goal is to make the construction more robust because with my Hemnes dressers and cabinets, especially with frequent use or heavier loads, the furniture tends to become a bit wobbly over time.
I have already tried some steps, such as adding extra screws or brackets, but I want to gather the best methods and tips that are possible without overly complex modifications.
Are there any proven tricks, special materials, or techniques to assemble or retrofit the furniture more securely? Thanks for your experiences and suggestions!
blapau
4 Jan 2023 08:42
One more practical tip: The material matters. Hemnes furniture is made from pine wood, which is relatively soft. If you use screws in areas that are not designed for the wood, it can reduce stability.
Therefore, I would recommend pre-drilling, especially for retrofitting, and using stainless steel screws with the appropriate thread. These provide better grip and minimize the risk of the wood splitting.
Additionally, it makes sense to use extra metal brackets or corner connectors specifically designed for furniture.
This way, you can reinforce the existing structure on a solid foundation.
Peose
4 Jan 2023 09:27
Awesome thread!! 😊
I always added the metal corner brackets from the hardware store to my HEMNES dressers and also placed small rubber pads underneath.
The difference is huge! The furniture is much more stable, wobbles less, and lasts much longer.
Just give it a try, it’s definitely worth it!
gasidney
4 Jan 2023 11:35
Secure the back panel properly, add metal brackets inside the corners, install diagonal cross braces, and fix the furniture to the wall.
chenValeri
4 Jan 2023 14:02
Use screws with pre-drilling; metal brackets reinforce the corners, and the back panel provides the main stability. Make sure to secure furniture to the wall.
Bueddie
5 Jan 2023 09:14
Thanks to everyone for the numerous and very helpful tips!
I will definitely tighten the back panels again and also try installing metal brackets. Additionally, I will try to add diagonal braces in key areas to prevent lateral wobbling.
I especially appreciate the advice about using the right screws and pre-drilling before fastening. I can probably improve on that.
Once I have everything assembled, I will share an update with photos and results. Thanks again for all the input!
