ᐅ How can I keep IKEA BESTÅ furniture permanently stable and free from wobbling?
Created on: 21 Sep 2016 08:13
O
Ortwinme
Hello everyone, I would like to start a discussion here in the forum about an issue that has been on my mind for some time: How can I keep IKEA Besta furniture permanently stable and free from wobbling? Specifically, I mean the typical TV units and shelving from the BESTA series, where the connections often loosen over time, causing the furniture to become unstable. I have read that tightening screws here and there can help, but I wonder if there are more sustainable solutions that also improve the durability of the joints. Are there any assembly tips, special materials, or additional components that can be used? I am also interested in whether there are problems that can be avoided from the start. Who has experience and advice on how to keep BESTA furniture stable and prevent it from becoming a troublesome project? Thank you in advance!
bareynaldo
22 Sep 2016 10:12
There is often talk here about screw repetition and angles, but I wonder: isn’t this just hypocrisy from the manufacturer? IKEA sells low-budget furniture that is not designed for long-lasting durability. The problem is artificially created to sell spare parts or new furniture.
I’ll take a risk and say: If you really want stable furniture, you shouldn’t use cheap pressed boards, but solid wood or a completely different system.
O
Ortwinme
22 Sep 2016 11:45
bareynaldo schrieb:
IKEA sells low-budget furniture, which is generally not designed for long-term durability.
That may certainly be true in many cases, but for me, Besta is quite an interesting system because of its modular and flexible use. For that very reason, I am looking for practical ways to make the system more durable and stable without having to switch to other furniture.
LuMarcel43 schrieb:
Maybe reinforcing it with corner brackets or an additional strip beneath the base would help?
That sounds reasonable. Are there specific types of brackets or strips that are especially recommended for Besta? Are there other details to consider regarding the material or the quality of the screws?
CHENNE
22 Sep 2016 13:05
For the stability of BESTA, I recommend the following approach:
- In addition to the supplied fasteners, use metal brackets on the inside corners to prevent twisting.
- Make sure to pre-install the dowels carefully during assembly and avoid pushing them in too deeply to ensure an optimal fit.
- Secure the back panel firmly with screws, as it serves as the “control mechanism” for bracing.
- Cable openings or other cutouts must not weaken the structure.
These measures are also important considering the cabinet material used, which is a relatively thin particleboard.
chenValeri
23 Sep 2016 08:48
I have successfully used adjustable-height furniture legs for the BESTA furniture. This compensates for minor floor unevenness and prevents any wobbling. It is also important to secure the furniture to the wall to avoid tipping movements.
lis64
23 Sep 2016 09:36
What helped me was using screws for the joints that are slightly longer than the original ones. This makes the parts fit together much tighter. However, you should be careful not to drill too deep into the material. Other than that, just the back panel and metal brackets – done.
dopite
23 Sep 2016 12:20
Ortwinme schrieb:
Are there specific types of brackets or moldings that are particularly recommended for BESTA?
For BESTA, flat metal brackets with pre-drilled holes, commonly known as furniture brackets made of galvanized steel, are suitable—ideally in sizes of 30x30 or 40x40 mm (1.2x1.6 inches). These are discreet, sturdy, and can be combined with the furniture’s screws.
Additionally, I recommend wooden strips made of beech or pine, with a thickness of 15-20 mm (0.6-0.8 inches), which you can attach underneath as cross braces. This significantly improves lateral stability. Important: Always pre-drill holes to avoid splitting the material.
In general: take some time to work carefully and use appropriately sized tools to avoid over-tightening screws. This will ensure the connections last longer.
