ᐅ Ikea Besta – How can I improve its stability after extended use?
Created on: 25 Jan 2023 14:37
fikrette
Hello everyone, I have had an Ikea Besta shelving unit in my living room for about three years, which I mainly use for books and decorations. Recently, I noticed that the furniture becomes a bit wobbly or loses stability after prolonged use—especially when I operate the doors or touch the unit. My question is: What options are there to sustainably improve the stability of Ikea Besta shelving units without having to replace all the parts? I suspect that some screws have loosened or the joints are giving way. Are there any specific reinforcements, effective tips, or alternative assembly methods that have proven successful? I would really appreciate it if you could share your experiences!
Hello fikrette, your idea is exactly right: a stronger back panel made of MDF or plywood is often the most effective and discreet way to permanently reinforce a Besta shelf unit. The new back panel doesn’t necessarily have to replace the original; you can also install it in addition to the existing one. Ideally, use small brackets or screws to securely fasten the back panel – this noticeably increases stability against lateral and torsional forces.
Regarding metal braces: yes, if the shelf carries heavy loads, crosswise metal profiles or wooden supports under the shelves help to prevent sagging. This can even be done with relatively simple methods, such as using U-shaped metal channels or sturdy wooden strips, which you screw to the underside of the shelves.
SETHBLA schrieb:
Metal profiles are practical. Exactly. And when all the screws are tight, these kinds of profiles make the shelf truly durable.
I once had a Besta that was quite worn and also wobbled – in the end, I just mounted two metal brackets per shelf on the sides. That made a big difference! I also screwed the shelf to the wall using brackets, which gives an additional sense of security. If the back panel is replaced, doing it with MDF isn’t much work either – just fit it well, and it looks great and helps a lot. 😊
A small tip from my experience: If you apply wood glue to the original dowels before reassembling, everything will hold more securely and last longer. Using dowels together with screws creates a firmer joint. This also prevents any creaking or movement at the connections. MDF as a back panel is fine, but be sure the surface does not warp – otherwise, it will pull the entire structure apart.
juMira46 schrieb:
If the back panel is replaced, using MDF isn’t much work either Thank you for the confirmation; it motivates me to finally tackle this project.
Wesley schrieb:
If you apply wood glue to the original dowels and then reassemble, everything will hold together more securely and for longer. I will definitely try the wood glue tip; it makes sense to improve both fit and fixation.
Overall, I now feel that the right combination of several measures—retightening screws, using glue, installing metal brackets, possibly mounting a stronger back panel—is the key. Thanks to everyone who contributed; you’ve helped me a lot!
