ᐅ How do the different Ikea Metod cabinet door materials age over time?
Created on: 12 Apr 2020 08:27
DUMOSU
DUMOSU
12 Apr 2020 08:27
some time ago, I started using an IKEA Metod kitchen with different door materials (mainly high-gloss, matte lacquered, and foil). I have noticed that over time, the doors show varying degrees of wear or quality issues. Therefore, I am specifically interested in how the different IKEA Metod door materials age with long-term use.
I am particularly interested in aspects such as:
- Susceptibility to scratches and abrasion
- Yellowing or discoloration from sunlight exposure
- Deformations like swelling or warping
- Wear caused by moisture on edges or handle areas
- Differences between surfaces like foil vs. lacquer vs. glass
Do you have practical experience or reliable information on how durable these door materials are and what I should watch for to minimize problems in the long run?
Svenja7
12 Apr 2020 09:43
Hello DUMOSU,
I have had a Metod kitchen with high-gloss fronts in daily use for about 4 years. Regarding your question about different signs of wear, I can share the following:
- High-gloss fronts are very susceptible to micro-scratches, especially from cleaning agents containing abrasive particles or from using harsh sponges.
- Yellowing is rare since the surface is usually made of painted MDF. However, panels exposed to direct sunlight for extended periods may darken slightly or develop a faint yellow tint.
- Moisture can affect the edges, particularly on foil fronts: after several years, small spots or peeling may occur.
- Matt lacquered fronts handle minor scratches better but tend to show fingerprints and stains more easily.
Here’s a tip: For maintenance, I recommend mild, grease-dissolving cleaners and soft cloths. Vigorous scrubbing quickly causes wear.
Overall, I would say all front materials visibly age over time, but the main differences lie in scratch sensitivity and moisture resistance.
JORGERON
12 Apr 2020 10:18
I have tested both foil fronts and lacquered fronts myself:
Foil fronts tend to peel off at the edges after about 5 years.
Lacquered MDF fronts are more prone to scratches but do not swell.
In short: foil is not very durable, lacquered fronts are more resistant.
roryvin
13 Apr 2020 07:52
DUMOSU,
here is a refined analysis of the most common material types in terms of wear behavior for Ikea Metod fronts:
- High-gloss lacquer (MDF): High scratch sensitivity due to the hard surface; micro-scratches from everyday use are unavoidable, but the surface remains uniform without cracks or chipping. UV resistance is quite satisfactory, with slight yellowing possible.
- Foil fronts (plastic foil on particleboard/MDF): Very prone to edge delamination, especially in the presence of moisture. Foil cracking and edge swelling are typical long-term issues. The surface does not tend to yellow and retains color intensity.
- Matt lacquered fronts: Less visibility of smudges, better scratch resistance due to the matte surface. The lacquered seal effectively repels moisture, though caution at the edges is still advised.
- Glass fronts (if present): Very durable and scratch-resistant, but sensitive to impact. No discoloration and easy to clean.
In summary, glued foil fronts prove to be the least durable, particularly when moisture is involved. Lacquered options offer a balanced mix of aesthetics and durability.
Care advice: Avoid abrasive cleaning agents, promptly wipe off moisture, and clean daily with suitable products to significantly extend longevity.
lochen
13 Apr 2020 10:06
roryvin schrieb:
Foil fronts (plastic foil on chipboard/MDF): Very prone to peeling at the edges, especially when exposed to moisture.
I can confirm that. I had foil fronts in my old kitchen, which after about 6 years showed bubbles and started peeling in several spots, mostly near the sink. In addition, the high-gloss fronts developed noticeable scratches after about 3 years, caused simply by cleaning with a sponge.
roryvin schrieb:
Matt lacquered fronts: Less visible smudges, better scratch resistance due to the matte surface.
I can confirm this as well. Matt lacquer usually looks better even after several years, even if minor scratches occur. There is a difference between microscopic damage to the material and scratches that are clearly visible.
My advice for anyone looking for a durable solution: Choose matt lacquered fronts, especially if children or households with heavy usage are involved.
ixlu1
14 Apr 2020 14:39
Very interesting topic! I love my Metod kitchen with matte lacquered fronts because they actually feel very durable – especially with everyday use like bumps or wiping.
What I have also noticed is that after about 5 years, the edges have softened a bit, showing slight rounding, probably due to minimal moisture absorption or constant use. That doesn’t bother me at all, as it feels like a "natural patina"!
lochen schrieb:
My tip to anyone looking for a long-lasting solution: better choose matte lacquered fronts
I fully agree! High gloss looks great, but maintenance is a hassle, especially if you have children or cook a lot!
I would also recommend keeping the edges really dry, as this greatly improves durability. Moisture is simply the main enemy.
