ᐅ How do I repair scratch-resistant IKEA Metod kitchen cabinet fronts?
Created on: 18 Apr 2021 08:17
fuklo5
Hello everyone, I have a question regarding the repair of scratch-resistant kitchen cabinet fronts from the Ikea Metod system. Specifically, it concerns some fine to medium scratches that have appeared through everyday use. Ikea often uses a special melamine coating that is supposed to be quite durable, but if the surface does get damaged, I’m wondering what the best approach is to fix scratches without having to replace the fronts entirely. Are there effective home remedies or professional repair kits that work for this? And if so, what is the proper procedure to treat the scratches without affecting the surface texture or the color tone? I have already tried thoroughly cleaning with polish and sponges, but the scratches remain visible. I would really appreciate tips based on experience, including which methods to avoid so it doesn’t get worse. Thanks in advance!
nera59 schrieb:
If you like, I can provide you with suitable product recommendations based on my own experience. Hello nera59, that would be very helpful! I want to use the most sustainable and safe materials possible. Tips on how to identify good quality products would also be great. Are there important differences between types of repair waxes or fillers that one should know? And when it comes to polishing, is it better to choose chemical or natural products? Thank you!
Certainly, here are my recommendations:
- Repair wax: Make sure it is specifically formulated for melamine or plastic surfaces. Products like “Idi Melamine Repair” or “PolyRepair” are popular among tradespeople. These waxes are usually pigmented to help match color variations.
- Repair kits with synthetic resin: These typically provide a more permanent fix but are somewhat more difficult to work with. They require patience for drying and sometimes additional sanding.
Both options have pros and cons: wax is easier to apply, less permanent, and ideal for surface imperfections; resin kits are more durable but more involved.
For polishing, I recommend chemical polish products designed specifically for melamine, as they preserve and renew the protective layer. Natural products like beeswax can be nice but are often not durable or may discolor the surface.
My tip: Always start small and test in a corner. Also, work in well-ventilated areas.
If you need more details, I’m happy to help!
nera59 schrieb:
For polishing, I recommend chemical polish products specifically designed for melamine, as they preserve and renew the protective layer. I agree, do not use home remedies like toothpaste or vinegar. They can damage the surface.Similar topics
