ᐅ How can I remove stubborn stains from Ikea Metod countertops?
Created on: 10 Dec 2020 18:27
Lonoba
Lonoba
10 Dec 2020 18:27
Hello everyone, I have a question about cleaning my Ikea Metod countertops, specifically the surface: How can I effectively remove stubborn stains without damaging the surface? I use the countertops in my kitchen and often deal with various stains such as dried coffee, red wine, and grease stains from extended cooking. So far, I have only used regular all-purpose cleaners, but these hardly help with older or dried-in stains. Are there specific cleaning products or methods that work particularly well for Ikea’s melamine coating, or perhaps some home remedies that I can safely use? I definitely want to avoid dulling or damaging the surface. Thanks for your advice!
sancamille
10 Dec 2020 19:03
For stubborn stains on Metod countertops, I recommend using vinegar water or dish soap with a sponge. Do not use abrasive cleaners to avoid scratching the surface. For dried-on coffee, a soft cloth and some soaking time will help.
Surela
11 Dec 2020 08:45
sancamille schrieb:
For stubborn stains on Metod countertops, I recommend vinegar water or dish soap with a sponge.
That is true, although I would use vinegar carefully, since too much acid can damage the protective layer on Metod countertops with a melamine surface. I would proceed as follows:
- First, treat the stains with a soft sponge and warm dishwater – this removes many contaminants.
- For dried-on stains, let it soak a bit longer, but avoid scrubbing like with sandpaper.
- If that does not help, you can carefully use a cleaning product with a mild pH, ideally one designed specifically for melamine or laminate.
- Never use harsh or abrasive cleaners! These damage the surface and can make stains worse later on.
For lightening discolorations, some household remedies can be suitable, such as a paste made from water and baking soda, but only in small amounts and tested locally. How do the stains look on your side? Are they rather surface-level or deeply embedded? How long have they been there?
Lonoba
11 Dec 2020 11:17
Surela schrieb:
What exactly do the stains look like on your side? Are they more surface-level or have they penetrated deeply? How long have they been there?
Good question. Most of the stains have been there for several days to weeks, for example, red wine stains from the last meal that I cleaned up too late. There are also dried coffee or grease splashes that seem to have partially absorbed into the surface. They are not as deep as stains in wood, but definitely no longer just surface-level. Additionally, I have a few dull spots that I can’t quite identify. I use the countertop daily and usually wipe it down with a damp cloth immediately after use, but sometimes residue simply remains. The surface is melamine-coated, like the kind offered by Ikea. I’m unsure if I can use aggressive cleaners without damaging the material.
Leonardteo
11 Dec 2020 16:32
Lonoba schrieb:
I’m unsure whether I can use aggressive cleaners without damaging the material.
That’s exactly the point: melamine-coated countertops, like the Ikea Metod, are fairly resistant to water and many cleaning agents, but acids and strong chemicals can actually damage the surface. For your stains, I recommend the following approach:
- Start with lukewarm water and a mild dish soap to avoid harming the surface.
- For dried-on stains, let a damp cloth sit for at least 10 minutes to soften them.
- For red wine stains, diluted lemon juice or a mix of water and baking soda can help—but always test first in an inconspicuous spot!
- Do not use abrasive cleaners, steel wool, or sharp scrubbing pads.
- Dull spots may be caused by aggressive cleaning or heat. If you don’t have any oily substances on hand, a specialized melamine cleaner (without abrasives) might help.
The key is to regularly wipe with clean water and keep the surface dry afterward. Have you already tried these gentle methods?
