ᐅ How can I remove stickers and labels from Ikea Besta without causing damage?
Created on: 4 Oct 2021 09:17
MANREO
MANREO
4 Oct 2021 09:17
Hello everyone, I have the following problem: I want to remove stickers and labels from my Ikea Besta furniture without damaging the surface. These are the usual paper labels as well as some glossy stickers that are quite stubborn in places. My main concern is not to damage the paint or the plastic surface, as I want to use the furniture for several more years. Can you give me tips on how to remove such stickers as residue-free and gently as possible? Are there any home remedies or professional methods you would recommend? I am also open to advice on the right tools and preparation. Thank you in advance!
Ethan
4 Oct 2021 09:45
Hello MANREO, your concern is completely understandable and important, especially when it comes to delicate surfaces like those on Ikea Besta. I would recommend starting with the gentlest methods possible. Often, carefully warming the sticker with a hairdryer helps, as it softens the adhesive and makes the labels easier to remove. Afterwards, you can gently lift any residue with a soft plastic scraper or an old credit card without scratching the surface. If some residue remains, sometimes a drop of a mild solvent like isopropanol on a soft cloth can help to remove the adhesive. Please be sure to test the solvent on an inconspicuous area first to ensure it does not damage the surface.
Ryder35
4 Oct 2021 10:01
Use a hairdryer, then lift with a plastic scraper. Nothing more.
Le_kin
4 Oct 2021 10:29
To address this topic in more detail: The adhesive layer on Ikea Besta furniture is usually delicate because it is made of melamine resin-coated particleboard or painted surfaces. The following method has worked well for me:
- First, warm the sticker for about 1-2 minutes using a hairdryer on low to medium heat. Be careful not to set the temperature too high to avoid warping or loosening the coating.
- Then, gently lift the sticker from the center using your fingers. If the sticker is stubborn, do not pull; instead, carefully assist with a flat plastic scraper.
- For adhesive residue, use a lint-free cloth lightly moistened with 70% isopropyl alcohol. Apply it carefully. It is important not to use too much liquid to avoid swelling or staining.
Another option is a special adhesive remover, but since Ikea furniture is often sensitive, I prefer isopropanol because it evaporates quickly. Test this on a hidden spot first, especially if your model has different surface types.
I would be interested to know how old your furniture is and whether the stickers are placed directly on the surface or on a protective film, as this can affect the removal method.
MANREO
4 Oct 2021 11:12
Ethan schrieb:
I would recommend starting with the gentlest methods possible. Often, gently warming the sticker with a hairdryer helps—the heat softens the adhesive, making the labels easier to remove.
Thanks, Ethan, I’ll try your hairdryer tip first; that already sounds very promising.
Le_kin schrieb:
I’m curious about how old your furniture is and whether the stickers are directly on the surface or on a protective film, as this can affect the removal method.
My furniture is about two years old, the surfaces are rather smooth and most likely have a melamine coating, as you described. The stickers are stuck directly on it, no protective films or anything like that.
I will try to use the hairdryer carefully and then lift the sticker with an old credit card. If there is any adhesive residue left, I would like to know exactly how to apply isopropanol gently to avoid damage. Do I need special cloths for that, or is a regular microfiber cloth sufficient?
Ethan
4 Oct 2021 11:39
MANREO schrieb:
If I still have adhesive residue, I would like to know exactly how carefully I should use isopropyl alcohol to avoid causing any damage.
Hello again, you should use isopropyl alcohol very sparingly. Lightly dip a lint-free cloth or, preferably, a cotton swab so that it is just slightly damp, not wet. Then try to gently blot and loosen the adhesive residue in small areas. Avoid rubbing too hard; instead, repeat the process several times if needed. After treatment, please wipe the area with a dry, soft cloth to remove any moisture from the surface.
A microfiber cloth is fine as long as it is truly lint-free. Sometimes a cotton cloth is also suitable, as long as it does not scratch. Many recommend using cotton swabs for small spots since they allow you to control the amount of liquid very precisely.
