ᐅ How do I properly clean IKEA Metod cabinet fronts without causing damage?
Created on: 8 Sep 2024 19:47
TANULI35
TANULI35
8 Sep 2024 19:47
Hello everyone, I’m looking for advice on the best way to clean IKEA Metod kitchen fronts without causing any damage. My fronts are white high-gloss lacquered, and I’ve found different recommendations online—ranging from mild soapy water to specialized cleaners. Since I want to avoid small scratches and discoloration, I’m especially interested in which cleaning agents and methods are truly suitable for keeping the surface gently but effectively clean. Also, how should I handle stubborn stains without affecting the lacquer or coating? If anyone has experience or useful everyday tips, I’d really appreciate your input. Thanks in advance for any constructive answers!
RENMA
8 Sep 2024 20:35
For cleaning IKEA Metod fronts, especially white high-gloss finishes, I recommend the following procedure:
- Use a soft, lint-free cloth, ideally microfiber cloths.
- Clean with warm water and a mild, pH-neutral dish detergent. Avoid abrasive cleaners or solvent-based products, as these can damage the surface.
- For stubborn stains, a mixture of water and a small amount of baking soda can be applied gently and then wiped off with a damp cloth.
- Never use coarse sponges or abrasive kitchen tools to prevent scratches.
- After cleaning, always wipe down with clear water and dry the surface to avoid water spots.
In summary: Mild, neutral cleaning agents, soft cloths, and gentle handling protect the high-gloss coating. The manufacturer's instructions on the IKEA website support these recommendations. For specific treated stains, spot cleaning with the above baking soda solution is advisable, but always test carefully first.
klo61
9 Sep 2024 07:22
RENMA schrieb:
For stubborn stains, a mixture of water and some baking soda is useful
That’s a great tip—I also use it for my Metod fronts. Additionally, you should always keep in mind that especially high-gloss lacquered fronts are sensitive to alcohol- or solvent-based cleaners. I also recommend testing any cleaner first on a small, inconspicuous area.
Generally, this works well for me:
- Gentle cleaning with warm water and a mild soap
- Never use overly wet cloths or apply too much water to the fronts
- For heavier dirt, such as grease, I use a solution with a little dish soap mixed in the water
- I avoid scratches completely by never using steel wool or abrasive sponges
If stains are very stubborn, you can carefully treat them with a soft cloth and a high-quality plastic eraser, but only if really necessary. So, always proceed gently and step by step.
warrenka57
10 Sep 2024 14:03
RENMA schrieb:
Never use coarse sponges or abrasive kitchen tools to avoid scratches.
I can only confirm that. At one point, a sharp-edged pot scrubber accidentally fell onto the cabinet front, leaving a small but clearly visible scratch. That really annoyed me – since then, I have been much more careful with the surfaces.
I also want to emphasize that I understand cleaning is sometimes unavoidable, especially with children or a lot of cooking at home. My experience has shown that patience and gentle, regular cleaning work better than infrequent, intensive cleaning, which can also be risky.
My advice: always clean up spills immediately, as dried or set-in stains are harder to remove.
