ᐅ How do I properly install Ikea Metod cabinets with soft-close drawers?
Created on: 1 Feb 2024 18:43
RenroHello everyone,
I am planning to install several IKEA Metod kitchen cabinets with soft-close drawers and want to make sure the assembly is done properly. It’s not just about the mechanical assembly but also about how to correctly adjust the soft-close function to ensure a durable and quiet drawer operation.
My detailed questions are:
- Are there any special preparations or tools that I should definitely have on hand to assemble the Metod cabinets cleanly and securely?
- How do I optimally adjust the soft-close drawers so they don’t close too quickly or too slowly?
- What should I pay attention to when aligning and adjusting the drawer slides to ensure smooth and consistent function?
- Are there common mistakes beginners make during assembly that I should definitely avoid?
I would appreciate detailed answers so I can benefit from your experience. Thank you in advance!
Hello Renro,
First of all, good preparation is essential. I often assemble Metod kitchen cabinets myself and here is a structured guide with some tips:
- Tools: Screwdriver (preferably a cordless drill with a Torx bit), spirit level, tape measure, and possibly a rubber mallet.
- Assembling the base structure: Make sure all parts are properly deburred, and the edges fit well together.
- Soft-close adjustment: The drawer slides usually have a small adjustment screw. You can use this to regulate the soft-close damping. Turn it in small increments and test the drawer each time.
- Alignment: Always use a spirit level when assembling the cabinets and hanging the fronts to immediately see if everything is straight. Small gaps between drawers are normal; what matters is parallel alignment.
Common mistakes:
- Mounting drawer runners not exactly parallel.
- Missing screw holes, causing the cabinet carcass to wobble.
- Soft-close mechanism adjusted too tightly, which makes the drawers close too slowly or not properly.
In summary: Patience during adjustment is key, and avoid forcing the fronts into place. If you need to readjust, always do so with small movements.
If you want me to explain any specific steps in more detail, feel free to ask.
Common mistakes:
Nathanaelk3 Feb 2024 14:28fredle schrieb:
Soft-close adjustment: Drawer slides usually have a small adjustment screw. You can use this to control the soft-close damping.That is basically correct, but with the IKEA Metod drawers you should pay close attention to which type of drawer slides you are using. There are different systems that can lead to slight differences in adjustment.
Here is a detailed step-by-step guide for proper installation and fine-tuning:
- Preparation: Check all delivered parts for defects and completeness, especially the soft-close mechanism and mounting hardware.
- Assemble the cabinet precisely according to the instructions. Use a spirit level to check vertical and horizontal alignment to avoid any twisting or tension. This is important to prevent alignment issues later on.
- Carefully install the drawer slides parallel to each other. Make sure the fixing holes are correctly aligned and the screws are tightened firmly to avoid any binding later.
- The soft-close units should be mounted so that they engage smoothly and without force on the slide rails. Pay attention to proper screwing.
- For adjusting the drawers, use the adjustment elements on the sides:
- Vertical alignment: Adjust until all fronts are at the same height.
- Side adjustment: Ensure the gap to neighboring cabinets and between drawer fronts is even.
- The damping on Metod can be influenced by turning the small screw on the soft-close unit. If set too strong, the drawers close slowly; if too weak, they slam shut.
Common pitfalls:
- Side rails not mounted parallel.
- Attaching fronts too early, causing the mechanism to become distorted.
- Underestimating fine adjustment, which often requires several small steps.
I wonder how many drawers you are installing in total? Then we could also discuss tips for series mounting.
Nathanaelk schrieb:
Typical pitfalls:
- Front panels screwed in too early, causing the mechanism to warp.
- Underestimating fine adjustment, which often should be done in several small steps.These points are often crucial. Additionally, I recommend:
- Before assembly, build and test all drawers and slides separately before attaching them to the cabinet. This prevents adjustment problems later on.
- Do not overtighten screws, especially on plastic parts, so the guiding components can still be finely adjusted.
- When inserting the drawer, make sure it is introduced completely level; otherwise, the soft-close function may jam.
In summary: Precise work and patience pay off. When all parts are cleanly and correctly positioned, you will enjoy the drawers for a long time.
It’s great to see such detailed help offered here!
