I am currently planning my new setup with Pax wardrobes from Ikea and am facing the challenge of creating a neat and functional corner connection. Specifically, I am wondering: How can I plan a corner connection with Pax wardrobes to make the best use of the space, ensure the wardrobes are properly connected, and avoid any annoying gaps or inaccessible areas?
I have read that there are special corner elements and accessories, but the planning is not straightforward, especially regarding dimensions, door orientation, and possible trim or cover panels.
If anyone has experience with planning such a corner connection—particularly which combinations of wardrobe types (e.g., with regular doors, sliding doors, corner units) work well and what to watch out for—I would really appreciate any advice and tips! Any information about structural stability, mounting, or example dimensions would also be very helpful.
Thank you in advance!
Hello and welcome to the forum! 😊
The corner connection is indeed a bit tricky, but with the right plan, it becomes easy. When working with Pax, it helps to take precise measurements from the start – not only of the angle but also the depth of the cabinets. Corner cabinets are great because they utilize often wasted space, especially those rotating carousels that are fantastic for storage.
I would recommend combining corner units with sliding doors if space is tight, since sliding doors don’t need to open as far. If you use regular hinged doors, keep in mind that the opening direction matters to prevent the doors from interfering with each other.
And very important: don’t skimp on cover panels! They ensure everything fits well and looks neat. If you set up Pax units that don’t fit exactly against the wall, the cover panels are perfect for hiding small gaps.
Good luck with your planning – and if you like, I can also send you some sketches I made for a similar situation.
Corner connection with Pax:
- Use a corner cabinet with a rotating inner unit
- Plan doors so they do not block each other
- Don’t forget fillers to close gaps
- Pay attention to the cabinet depth (usually 35cm (14 inches) or 58cm (23 inches))
- Measure the distance to the wall precisely
To accurately plan a corner installation using Pax wardrobe systems, the following factors should be considered:
- Room measurement: In addition to measuring lengths, the angle of the corner is crucial. Use a protractor or digital measuring device to determine the exact angle.
- Wardrobe dimensions: Pax wardrobes come in standardized widths and depths, typically 35 or 58 cm (14 or 23 inches) deep and widths of 50, 75, or 100 cm (20, 30, or 39 inches). For corners, a special corner wardrobe with a hinged door or carousel unit is usually recommended to make the best use of the space.
- Connecting the wardrobes: For stability, it is important to join the wardrobes with the designated connector fittings. Pay attention to proper fastening to walls and ceilings according to the assembly instructions.
- Doors and opening direction: When arranging corner units, check if doors overlap when opened. Sliding doors can be a good solution to save space.
- Appearance: Filler panels are important to cover minor wall irregularities or side gaps and to create a uniform finish.
The Ikea planning tool can assist in this process, but manual verification of measurements provides additional assurance.
In summary, I recommend taking precise measurements and angle recordings before purchase, optionally preparing a sketch with all relevant dimensions, and following the assembly and safety instructions provided by Ikea.
Trate47 schrieb:
Corner cabinets are great because they make use of often wasted space; those rotating carousels are especially brilliant for storage.That’s generally true, but I wonder if a rotating carousel in a corner cabinet can sometimes be impractical. For example, if the cabinet is too deep, access to the rear area might still be limited despite the rotation mechanism. I would recommend first clarifying whether the carousel really suits your daily needs or if an open corner shelf or a sliding door system might be more appropriate.
Benge5 schrieb:
For stability, it’s important to join the cabinets using the recommended connecting fittings.I agree, but you also need to consider the wall structure. With particularly slanted walls, additional spacers or special brackets are sometimes needed to make the corner connection both stable and visually clean.
Ultimately, the requirements and intended use of the corner cabinet should be clearly defined before choosing a specific system.
What does your space look like exactly? What are the measurements of the corner and how deep are the adjoining walls?
