ᐅ How can I make Billy shelves child-safe without compromising their stability?
Created on: 28 Apr 2021 09:12
TEMUSIN
Hello everyone, I have a fairly simple but important question: I’m looking for ways to make my IKEA Billy bookshelves childproof without compromising their stability. Specifically, I want to prevent the shelves from tipping over without weakening the structure or reducing the load-bearing capacity. I’ve heard about wall anchoring options, but there are many different methods and materials—some said to be more stable than others. I’m also interested in any recommended modifications inside the shelves to increase safety, such as reinforcements or other tips. Maybe someone has a combination of installation and material advice that has proven effective in everyday use? Thanks in advance!
jotisi
29 Apr 2021 08:12
Victor54 schrieb:
Drill properly once, use anchors with sufficient load capacity and preferably metal brackets
Sure, if you are allowed to drill into the wall. But what if the landlord doesn’t permit it? Is there an alternative solution that still provides stability? Or is anything without wall mounting just a false promise?
TEMUSIN
29 Apr 2021 09:35
jotisi schrieb:
But what happens if the landlord does not allow it?
That is exactly the challenge I am facing. Drilling is not strictly prohibited, but it is complicated due to handovers and other formalities. I have seen alternatives like tension straps between the shelf and the ceiling, but I am doubtful about their durability. Does anyone have experience with such non-invasive solutions that are still stable?
JONKO
29 Apr 2021 10:05
TEMUSIN schrieb:
Alternatives like tension straps between the shelf and ceiling have been seen, but there are doubts about their durability.
These can be practical in some cases if the ceiling is sufficiently load-bearing and the attachment is properly executed. However, tension straps or ceiling rods often move with the motions. This reduces long-term safety, especially with active children. My advice would be to weigh down the shelves from the inside with additional heavy objects and teach children well not to climb.
LIELCHEN
30 Apr 2021 11:48
I would strongly advise against relying solely on unconventional solutions like tension straps when it comes to child safety. The best option is always a secure wall mount, which you can make reversible with good toggle bolts in case of moves or renovations. And for indoors, always store heavy items at the bottom, as this greatly reduces the risk of tipping.
V
Victor54
30 Apr 2021 12:23
jotisi schrieb:
Or is everything without wall mounting just an illusion?
Shifting the center of gravity alone can already have a big effect with small children, but the shelf always remains a potential tipping hazard without wall mounting. From a purely structural standpoint, the leverage is much too great. Multiple safety measures combined are the only way to achieve truly reliable stability.
jotisi
1 May 2021 07:17
You all make good points. Perhaps this discussion is also an example of how the ideal and the realistic often diverge. In practice, a compromise is often enough: proper wall fixings, yes, but also careful placement and weight distribution, along with educational measures. Unfortunately, 100% safety probably doesn’t even exist with shelving units like Billy.
