ᐅ What should I do if my Billy shelf is wobbling even though it is attached to the wall?
Created on: 25 Sep 2021 08:13
Sansau
Sansau
25 Sep 2021 08:13
Hello everyone, I have a Billy bookcase from IKEA that I have securely attached to the wall. However, it still noticeably wobbles, especially when I gently shake it. The fastening is done with the recommended plugs and screws, so it should be properly installed. My question is: What can I do if a Billy bookcase wobbles despite being fixed to the wall? Could it be due to the material, the assembly itself, or the wall? I am open to any advice, including what to check or possibly reinforce.
bupar
25 Sep 2021 09:04
The most common reason for a wobbly Billy shelf despite correct wall mounting is either the type of fixing used or the condition of the wall. First, check whether the anchors are properly seated and the screws are tightened securely. For example, in drywall (plasterboard) walls, simple anchors are often not sufficient. In these cases, specialized cavity anchors or metal anchors are recommended. You should also ensure that the shelf is fixed at multiple points, ideally both at the top and bottom. If the wall itself is porous or damaged, this can cause the fixing to not hold properly.
GALEO4
25 Sep 2021 09:33
bupar schrieb:
The most common cause of a wobbly Billy shelf despite proper wall mounting is either the type of fasteners used or the nature of the wall itself.
Interesting perspective, but I doubt that standard wall plugs are always to blame. It might simply be that the Billy shelf cannot be perfectly stabilized due to its design. Anyone who wants to securely mount a shelf like Billy for heavy loads will probably need to invest in a different shelving system.
Matthewt48
25 Sep 2021 10:02
Criticism of the construction is one approach, but the Billy shelf itself is stable if all parts are assembled correctly. What is often overlooked is that the back panel made of thin particleboard contributes significantly to rigidity. If the back panel does not fit precisely or is only loosely attached, wobbling can occur. Therefore, check whether the back panel is firmly nailed or screwed in place without any gaps. Additional brackets can also be used for reinforcement.
GALEO4
25 Sep 2021 10:19
Matthewt48 schrieb:
Check whether the back panel is firmly nailed or screwed in place and that there are no gaps.
That makes sense, but that’s exactly why I say it’s a design issue: a thin back panel is never truly stable enough. For people who want absolute stability, the Billy is a makeshift solution because this type of shelving is designed to be minimalist and inexpensive.
You could easily reinforce the Billy by attaching an additional layer of chipboard to the back and screwing it in for increased stability.
Lis53
25 Sep 2021 12:06
The most important step is a thorough check of the fastening: Are the screws actually fixed into wall brackets with sufficient load-bearing capacity? In drywall constructions, hollow wall anchors should be used to prevent pull-out. Additionally, small brackets can be installed on the lower half of the shelf to secure it against tipping and wobbling. Ideally, at least two fastening points per shelf board should be used – a single screw mounted only at the top is often not enough.
