ᐅ Increase the stability of the BILLY shelving unit with additional fasteners.
Created on: 2 Jun 2022 08:12
Neosamir
I recently bought a Billy shelf from IKEA to better organize my workspace. However, I noticed that the shelf feels quite wobbly, especially when loaded with books. My question is: what practical additional fastenings or measures would you recommend to significantly improve the stability of the BILLY shelf? I would prefer not to rely solely on the supplied wall anchors, but am looking for strong yet simple solutions that provide lasting support without compromising the appearance too much. I am also interested in hearing if you have had any practical experience with alternatives such as extra brackets, screws between the shelves, or even custom constructions.
bensau
2 Jun 2022 11:03
I think the combination of function and appearance is very important – when I want to stabilize my Billy shelf, I often use small, barely visible brackets attached under the shelves. They reinforce it without making it look like a makeshift solution. Additionally, I have experimented with thin wooden strips on the back panels. This adds a little extra "wow factor" in stability without compromising the furniture. ?
V
Vinlen
2 Jun 2022 11:25
An additional MDF back panel significantly increases stability, especially for bulky shelves like the BILLY. For a visually clean solution, it is important that the back panel is at least 4 mm (0.16 inches) thick and fixed with screws or small nails. This provides high lateral stiffness and prevents wobbling, particularly when storing heavy loads. If needed, the back panel can also be further secured from the inside with brackets.
PEDRO40
2 Jun 2022 11:54
I used to have similar concerns; the situation improves once the wall mounting is properly secured. However, to ensure the shelf is firmly stable, I also placed small adjustable plastic feet underneath the sides. This helped me compensate for any unevenness in the floor and improve stability.
It is important to always screw the shelf to the wall, as this significantly reduces most of the wobbling issues.
Lamar
2 Jun 2022 12:17
It is interesting that everyone here immediately relies on wall fastenings and back panels. In my experience, the effectiveness of these measures is often overestimated. BILLY shelves are not designed to support heavy loads by nature. If you really want stability, you should choose a completely different shelving model – or build something yourself.
Neosamir schrieb:
I prefer not to rely solely on the included wall fastenings, but I am looking for robust yet simple solutions
That is a clear contradiction. Either you have professional-level stability, or it remains a compromise solution – extra brackets and screws do not replace a solid shelving design.
semuneo
2 Jun 2022 12:45
Lamar schrieb:
Either you have professional-level stability or it remains a compromise solution
I understand your point and respect your opinion. However, I also believe that many of us are looking for small, practical improvements while considering budget and effort.
To add some information: I cut a thin plywood panel to size, attached it to the inside of the back panel with screws, and beforehand covered it with a decorative finish that I applied myself. This way, the "reinforcement" is barely visible. The shelf is now noticeably more stable, and I feel confident placing heavy books on it.
If needed, I’m happy to provide more detailed measurements and types of screws used.
BELLA34
2 Jun 2022 13:11
It is important that the shelf is securely fixed to the wall.
Additionally, make sure to attach small brackets on both the right and left sides.
Without wall fastening, you cannot expect anything stable or effective.
