ᐅ BILLY Shelf Screws Losing Grip: How to Fix?
Created on: 18 Apr 2024 08:43
V
vitus
V
vitus
18 Apr 2024 08:43
Hello everyone, I have a Billy shelf from Ikea where the screws in the side panels are gradually losing their grip. This means the joints become loose, and the shelf feels unstable during use. Since I don’t want to completely disassemble or damage the shelf, I’m looking for the most effective way to reinforce the screws without major modifications or replacing entire panels. Does anyone have experience or tips on how to repair the screw holes in the Billy shelf to ensure the screws hold securely again? Thanks in advance!
MOMIRA
18 Apr 2024 09:12
Hello, just put some wood glue into the hole, then insert the screw and let it dry briefly. This usually secures the screw firmly again. If that’s not enough, try the toothpick method: insert a few wooden sticks or toothpicks into the hole, drip glue on them, break off the excess, and then screw in.
Ramon4
18 Apr 2024 10:03
Hello vitus, your problem is unfortunately common with furniture made from engineered wood products like BILLY shelves. Over time, the screws pull through the material and lose their grip, especially if the load is higher or the furniture is frequently moved. The classic repair method is actually to fill the screw hole. There are several options for doing this:
1. Use wood glue and insert a wooden dowel or wooden stick to effectively reshape the hole.
2. Use special repair fillers or wood putty to stabilize the hole.
3. If possible, use a slightly larger screw that provides more grip in the fragile material.
It is important to let everything dry completely after the repair and then carefully load the shelf again. If you want, I can explain the individual steps in more detail.
nolan
18 Apr 2024 10:14
Apply wood glue and insert a toothpick or small wooden dowel into the hole, then carefully screw in the screw. This ensures a secure fit. It should hold.
Dilen
18 Apr 2024 12:26
Hello vitus,
to address your issue comprehensively, we first need to understand the type of screws Ikea uses in the BILLY shelf, which are usually chipboard screws with coarse threads designed for wood-based materials. The reason for the loosening is due to compression and the fraying of the wood composite, especially if the shelf has been frequently disassembled or subjected to heavy loads.
A proven repair method:
1. Carefully remove the screw.
2. Clean the hole from any loose wood fibers.
3. Completely fill the drilled hole with wood glue (if necessary, also use PVA glue) and insert precisely fitting wooden sticks or small dowels.
4. Make sure the wooden pieces fit tightly and the hole is well filled.
5. Reinsert the screw. The moisture in the glue will dry and effectively reseal the hole.
Important: Allow the glue to dry for at least 24 hours to achieve maximum strength! Have you also checked if the screws themselves are still in good condition?
Sometimes it helps to switch to the next larger screw diameter, provided the side panels allow this and are not further damaged.
Could you also describe where exactly on the shelf the problem mainly occurs? Side panels, back panel, or areas near the shelves?
bauku
18 Apr 2024 13:50
It's great to see so many helpful tips here already! 🙂 I once repaired something similar with wooden dowels when the screws in my BILLY shelf became loose. The important thing is to insert the dowels after applying glue and then let it dry thoroughly. After that, my shelf stood like new again! Give it a try, it really works!
