ᐅ Increasing the floor load capacity of a Billy Regal – is reinforcement necessary?
Created on: 17 Jun 2023 19:03
Kaijo
Hello everyone, I recently bought a Billy bookshelf from IKEA and want to set it up on a ground floor location where the load capacity seems to be higher than usual. My question is: Is it necessary to increase the floor load capacity or reinforce the bookshelf in any way if I plan to load it with heavier items to ensure long-term stability and safety? I am particularly interested in whether it is recommended to strengthen the floor or the bookshelf itself, and what simple measures are useful to prevent damage to the floor or tipping of the bookshelf. Thanks in advance for your assessments and advice!
Jeffon
18 Jun 2023 08:53
The shelves of the Billy unit are made of particleboard with a decorative foil and can carry up to 30 kg (66 lbs) evenly distributed, as stated in the manual.
Floor reinforcement is only advisable for exceptionally soft or unstable flooring.
Alternatively, the unit can be secured to the wall to minimize the risk of tipping, which is often more important than floor reinforcement.
DEOLAU
18 Jun 2023 10:27
Wall mounting is mandatory for higher loads. Increase floor load capacity? Rarely necessary, except for very sensitive floors. Simply use large felt pads underneath to distribute the load.
RENMA
18 Jun 2023 11:43
Hector schrieb:
Also keep in mind that reinforcing the floor only makes sense if there is clear damage visible or a structural weakness present.
I agree with that. A general recommendation for reinforcement is not effective without knowing the specific circumstances.
My advice: Use a scale to measure the point load on the legs and check the condition of the floor. For example, pressure marks can appear quickly on wooden floorboards, whereas concrete floors are less prone to this.
Siflo
19 Jun 2023 09:01
Jeffon schrieb:
Alternatively, you can secure the shelf to the wall to minimize the risk of tipping, which is often more important than reinforcing the floor.
Exactly, fixing the shelf to the wall significantly reduces the risk of accidents.
Additionally, simple measures like felt pads or load distribution plates can help reduce peak loads.
On the other hand, structural reinforcement of the shelf is only necessary with truly excessive loads, such as when storing heavy tools.
Kaijo
20 Jun 2023 14:17
Thank you for the many helpful contributions and assessments!
In summary, I understand that with moderate loads and typical flooring, special reinforcement is usually not necessary. However, with very sensitive substrates or significantly increased loads, simple measures like felt or rubber pads and wall fixing are important.
I plan to store larger books and some heavy binders, which should weigh about 20-25 kg (44-55 lbs) per shelf, on laminate flooring. I will probably use a distribution board underneath and fix the shelf to the wall.
If anyone has specific advice on choosing the distribution board, I would appreciate it!
