ᐅ Fitting a Billy Shelf Unit with Drawers – What Are the Options?
Created on: 14 Dec 2022 08:13
ben42
I would like to equip my Billy bookshelf with drawers and I’m wondering what options are available. Specifically, I’m interested in what types of drawers can be retrofitted to an existing Billy bookshelf without damaging or destabilizing the shelf itself. Also important: what about the load capacity, and are there any special fasteners or kits that you would recommend?
Does anyone have experience with these kinds of modifications or perhaps tips on installation and materials?
Looking forward to your opinions!
andre3
14 Dec 2022 10:59
Technical Implementation:
1. The load capacity of the drawers is generally around 8 kg (17.6 lbs).
2. Installation requires screws in the side panels of the shelving unit; these must be in perfect condition.
3. An alternative is drawer inserts without fixed mounting, which simply sit inside the shelving unit.
4. Additional wall mounting of the shelving unit is recommended for extra load-bearing.
When choosing drawers, pay attention to materials that are as thin as possible yet sturdy. Metal runners provide better durability than plastic ones.
Naomige
14 Dec 2022 11:11
Hello ben42,
I would recommend first checking whether your Billy shelf is in good condition—meaning no swollen or damaged wooden parts. If everything is stable, adding drawers is indeed a good way to neatly store small items.
In newer models, there are often drawer inserts that can be installed easily. When assembling, make sure to attach the rails straight and at the same height to ensure smooth opening and closing.
In general, I also suggest checking and securing the wall mounting before installation, as this increases the safety of the shelf. If you need help with that, just let me know!
Kukar
14 Dec 2022 14:24
Doesn't fit originally, but:
There are third-party drawer boxes available in various sizes that can be placed inside Billy. Permanent installation is possible in a DIY style, but should be done with caution. The quality of the boxes varies significantly.
ben42
15 Dec 2022 08:36
Thanks for your input! I was also considering the load-bearing capacity and secure wall mounting.
Hector schrieb:
Whether a Billy shelf is even designed for drawers.
I would like to ask for some more detailed information: Do you have any technical data or practical experience that shows what loads the shelf can safely support sideways and forward? This would be quite important for the planning.
Regarding assembly:
Does anyone have specific recommendations on which screws (size, length) work best to minimize damage to the shelf while still ensuring a stable fixing?
The goal is to create a modification that is as reversible as possible without failure.
Friedrich
15 Dec 2022 09:20
Regarding loads: I compared the shelf to standard bookcases. The side panels are not solid but usually made of compressed wood fibers.
With heavy weight on the drawers, there are real risks. The screws should be inserted into the pre-drilled holes in the side panels to prevent the material from splitting. In my case, 3cm (1.2 inches) long wood screws were sufficient.
ben42 schrieb:
einen möglichst reversiblen Umbau ohne Versagen zu schaffen.
I would recommend drilling only into secondary surfaces and possibly supporting the rest of the structure with clamp or plug-in systems.
raulso
15 Dec 2022 10:04
Light and easy to add:
Also quite handy are rolling drawer inserts that you can simply slide into the bottom of a shelf. You hardly need to screw anything, and you can easily take the boxes out when needed.
Sometimes, that’s the best compromise between functionality and flexibility. 😄
