ᐅ BILLY shelf wobbles after I added shelves: Why?
Created on: 18 Sep 2022 17:04
lolela
I have a Billy shelving unit from IKEA that has been very stable so far. However, after adding some additional shelves, I noticed that the unit now wobbles a bit and doesn’t stand as firmly as before. I installed the shelves exactly in the designated positions and checked that they are properly seated.
My question is: Why does the BILLY shelving unit wobble after adding shelves? Is there a technical or structural reason why its stability might be affected by this?
I would appreciate any advice, including how to best fix the problem if possible.
PeoDaniel
19 Sep 2022 10:25
One idea: Have you checked if the rear wall is properly aligned over the entire surface and not slightly detached in some areas? Even small gaps can contribute to wobbling.
If this is not possible, sometimes an additional wall fastener can help improve stability.
lolela
19 Sep 2022 13:50
klo61 schrieb:
Absolutely yes, especially with tall shelves.
Thanks, that’s a good point. The shelf is about 2 meters (6.6 feet) high. I will try to better level the adjustable feet or place something underneath.
Ethan schrieb:
That’s typical of insufficient lateral stability.
I haven’t changed anything on the side panels yet, but it’s quite possible that the shelf twists a bit more with additional shelves.
I’m also considering adding an extra wall mounting, even though I haven’t used one so far.
liRaul49
19 Sep 2022 15:28
In summary:
- Level the base surface
- Properly secure the back panel
- Place the shelves on all metal pins
- Optionally use wall mounting
That should help.
reni45
20 Sep 2022 08:37
Try gently pressing the shelf against the wall at the lower corner and secure it there with small spacers or washers. This can significantly reduce the wobbling.
EDWARD0
20 Sep 2022 10:12
Also important: The metal pins supporting the floors must be perfectly straight. If they become slightly bent due to frequent repositioning, the stability will be compromised. It is worth checking.
lolela
20 Sep 2022 11:45
Today, I tried to level the base area using small shims and tightened the back panel again. I also installed the wall mounting.
Result: The wobbling is significantly reduced, almost unnoticeable. Thanks to everyone for the helpful tips, especially regarding leveling the floor and securing the back panel.
If the problem occurs again, I will pay close attention to the metal pins.
