ᐅ What issues can arise when using BILLY as a TV stand?
Created on: 22 Aug 2024 10:17
Joeyken
Lately, I have been using IKEA’s BILLY shelves as a TV stand, which seems practical because they are flexible and affordable. However, some issues appear to arise when using them as a TV stand, and I would like to explore these in more detail. Specifically, I am interested in hearing about typical challenges other users have encountered when using BILLY as a TV stand. These include problems with load capacity, stability, cable management, or the available space for media devices.
I would really appreciate well-informed feedback, including any specific modifications or solutions you have found. Thanks in advance!
dijan
22 Aug 2024 15:29
Oh, I see this with a wink: Billy as a TV stand? A brilliant budget solution if you know its limits! 😉
But seriously, cable management with BILLY is a bit of a challenge. The open back panels help, but without some initiative, it quickly looks very messy.
Small cable clips or cable channels on the back of the shelf are a real game changer here. Saves nerves and looks better too.
Marcellela
22 Aug 2024 16:53
Stability: Wall mounting is mandatory.
Depth: Buy shelves at least 40 cm (16 inches) deep.
Cables: Use cable ties or small clips.
Otherwise, it quickly becomes unstable and messy.
ju_ren
23 Aug 2024 09:11
Joeyken schrieb:
How sturdy are the supplied shelves?
They are made of pressed wood and support smaller devices under 15 kg (33 lbs) well. For heavier loads, I recommend reinforcing them or using solid wood boards.
Joeyken schrieb:
Experience with TVs over 50 inches?
Caution is advised here. Larger TVs are usually heavier and require sturdier supports or dedicated TV furniture.
SETHBLA
23 Aug 2024 09:45
I use BILLY as a TV shelf, but only for smaller equipment, while I place the TV itself on a separate TV stand.
I haven't experienced any load-bearing issues this way, but it can become critical with larger devices.
The biggest issue for me is leftover cables; without a back panel, it quickly looks cluttered.
Lorukeo
24 Aug 2024 08:38
likuken schrieb:
whether it is better to buy something more specialized for technical devices
I agree. BILLY is affordable and versatile, but the design parameters clearly limit its use as a TV stand. You should carefully check the expected load and device dimensions before purchasing.
Additionally, extra measures such as wall mounting, using the deeper version, and targeted cable management are essential to minimize risks and avoid problems.
dijan
24 Aug 2024 11:02
Finally, a tip: If you use BILLY for the TV, you should at least not skimp on stability.
Cable clips, additional wooden battens for reinforcement, and a solid wall mounting can work wonders.
And if the budget allows: It’s better to place the TV on a proper TV unit. This will save you trouble later on 😉
