ᐅ How can I gently clean Ikea BRIMNES furniture?
Created on: 31 Aug 2020 19:03
Kimsi
Kimsi
31 Aug 2020 19:03
Hello everyone, I recently purchased some furniture from the Ikea Brimnes series. It’s important to me to clean these pieces gently yet effectively, so the surface doesn’t get damaged and the furniture keeps looking good for a long time.
Specifically, I’m interested in which cleaning products and methods are recommended for removing dirt such as dust, fingerprints, hardened grime, or small stains without using harsh chemicals.
Are there any experiences with certain cloths (microfiber, cotton, etc.), cleaning agents, or home remedies? And what should definitely be avoided to prevent scratches or dull spots?
I’m looking forward to your advice, tips, and also insights into common mistakes to avoid when cleaning BRIMNES furniture.
BEATE
31 Aug 2020 19:21
For Ikea BRIMNES furniture, usually a dry or slightly damp microfiber cloth is sufficient.
Do not use harsh cleaners or abrasive materials.
Only mild soapy water should be used if there is stubborn dirt.
Ernesto
1 Sep 2020 07:58
First of all, it is important to know that the BRIMNES furniture from Ikea is usually made of coated wood-based materials protected by a melamine resin layer. This means the surface is quite resistant to moisture, but mechanical scratches and aggressive chemicals should be avoided as they can damage the protective coating.
My tip: Always use a soft, lint-free microfiber cloth that is slightly dampened for wiping. Make sure not to leave standing water puddles, as water over time can damage the edges. For lightly greasy stains, you can use a mild dish soap in lukewarm water.
Very important: Avoid any solvent-based products, bleach, or abrasive substances. Waxes or polishes are also unsuitable, as they can leave a greasy residue and affect the original appearance.
Additionally, to remove stubborn stains, you can carefully work with a small sponge and a few drops of vinegar in water, but always wipe off immediately with clean water.
I would be interested to know: Where exactly are the most significant stains on your furniture? For example, are they on handles, tabletops, or surfaces that often show fingerprints? This way, the cleaning process could be even more targeted.
Kimsi
1 Sep 2020 09:43
Ernesto schrieb:
I’m curious: Where exactly do you notice the most dirt or smudges? Is it on handles, tabletops, or surfaces that often show fingerprints? This could help tailor the cleaning process more effectively.
Thank you for the detailed answer! The most noticeable dirt is on the fronts of the BRIMNES dresser, meaning the surfaces themselves. There are fingerprints and some dust, as well as a few small smudges from children. The handles are made of plastic and easy to clean, but it’s especially the matte surface that seems sensitive, so I want to use gentle, nourishing cleaning products rather than harsh ones.
REPITAR
1 Sep 2020 15:12
Hello Kimsi, I’m happy to provide you with a step-by-step guide for gently cleaning your Ikea BRIMNES furniture:
- Preparation: Remove dust and loose dirt using a dry microfiber cloth or a soft duster. This helps prevent scratching.
- Cleaning solution: Mix lukewarm water with a few drops of mild dish soap. Avoid harsh cleaners or ammonia.
- Cleaning: Dip a soft cloth into the solution and wring it out well so it is only slightly damp. Wipe the surfaces, gently rubbing any stains.
- Rinse: Wipe the area again with a second cloth dampened with plain water to remove any residue.
- Drying: Immediately dry the surfaces with a dry, soft cloth to prevent water spots and damage.
- Caution: Avoid scouring pads, sharp blades, or wax/polishing products, as these can damage the coating.
Common mistakes include cleaning with too much water and using aggressive agents that especially damage edges. If you want to try something new, test the solution first in an inconspicuous spot.
I hope this helps!
NOAHSAU
2 Sep 2020 21:46
BEATE schrieb:
Usually, a dry or slightly damp microfiber cloth is enough for Ikea BRIMNES furniture.
That may be true, but I find that approach too minimal in the long run. Of course, you don’t want to damage the surface, but if you only dust occasionally, grease spots and other marks tend to stay too long. I have had good results using a mild vinegar-water solution—especially on white BRIMNES surfaces, where it helps reduce visible stains and makes the furniture look cleaner.
I also recommend turning cleaning into a small maintenance routine rather than just a quick task. This includes controlled moisture, avoiding water accumulation, and occasionally wiping the edges, which are often overlooked. Those who keep cleaning to a minimum miss the chance to really preserve their furniture’s appearance for a long time.
