Hello everyone, I have a problem with a misaligned door in my Ikea Metod kitchen. Specifically, the door no longer hangs straight; it shifts slightly downward and to the right when I close it. Most likely, the hinges are no longer properly adjusted, or possibly the screws have come loose.
I am especially interested in how to reliably realign the door myself so that it doesn’t shift again after a short time. Is there a proven method for readjusting the Metod hinges or any installation tips that are useful to know? Any advice on how to check for or fix potential damage to the screws or hinges would also be appreciated.
If anyone has specific tips on handling Ikea Metod doors, I would be very grateful to hear about your experience!
vinpau schrieb:
If the screws are too loose, a bit of wood glue or wood shavings under the screw often helps, especially if the hole has become worn out.Thanks for the tip about the wood shavings, that’s exactly my problem – the hole has some play. Do you think it’s better to glue it with wood glue or to use proper dowels?
draleo schrieb:
If the screws don’t hold because the drilled holes are worn out, wood wedges or special dowels can be used for stabilization.Is there a recommended approach that has proven particularly effective with Metod cabinets? I’d rather avoid ordering expensive replacements if I can fix the problem with simple means.
Jeron1 schrieb:
Is there a recommended procedure that has proven effective specifically for Metod cabinets?Yes, if the screw hole is stripped, I suggest the following steps:
- Remove the screw and clean out the old wood material from the bore hole.
- Coat a toothpick or several small wood shavings with wood glue and insert them into the hole.
- Allow the glue to dry completely (about 24 hours).
- Then carefully drill a small pilot hole with an appropriate drill bit.
- Screw the screw back in.
This method provides a strong hold and is cost-effective. Dowels are usually oversized for Metod doors and can cause cracks in the thin wood when tightened.
If the door is severely damaged, replacing the front might be more appropriate, but for minor repairs, this method is the most practical.
