ᐅ How do I securely install Ikea Metod wall cabinets?
Created on: 12 Apr 2023 08:36
Jukla66
Good morning everyone, I am currently planning to install Ikea Metod wall cabinets in my new kitchen and want to ensure they are securely and safely mounted to the wall for the long term. I have reviewed the instructions, but some points are still not entirely clear to me, especially regarding mounting on different types of walls (e.g., concrete vs. drywall) and the maximum load capacity of the cabinets in relation to the anchors and screws used. Additionally, I am interested in any tips you have for leveling the cabinets properly so they hang straight and don’t tilt forward or become loose over time. What experiences do you have, particularly with older walls or uneven surfaces? I look forward to your practical advice and suggestions, and thank you in advance!
Jukla66
13 Apr 2023 07:44
warrenka57 schrieb:
Especially when there are children in the house, this makes a huge difference to me in terms of safety.
You bring up an important point, thanks! Are there any concrete recommendations or experiences regarding how many screws and anchors per cabinet are appropriate or perhaps too many? For securing the bottom side, angle brackets seem to be a recommended measure – do you use special brackets or just standard ones?
LUISABEL schrieb:
The load capacity largely depends on choosing the correct anchors, but also on the fixing method – for example, the substructure behind drywall needs to be strong enough.
What can you say specifically about the substructure? I have drywall with metal studs behind it – is that sufficient?
BOSULE
13 Apr 2023 08:59
Regarding the substructure for drywall systems: Metal profiles are generally not strong enough to support heavy Metod wall cabinets.
- Ideally, reinforce the wall with additional wooden battens screwed perpendicular to the metal profiles.
- Alternatively, the cabinets can be mounted directly on load-bearing walls or an intermediate framework can be installed.
- Brackets fixed underneath are very helpful to reduce stress on the fixing points, especially for wider cabinets.
The number of anchors and screws should be at least according to the manufacturer’s instructions; for uncertain walls, use more.
SANMAR
13 Apr 2023 09:10
I also found installing my Metod wall cabinets on drywall quite challenging at first.
Jukla66 schrieb:
For securing the bottom, angle brackets are a recommended solution – do you use special angles or just standard ones?
I use simple, galvanized angle brackets that are properly sized (at least 40x40 mm (1.6x1.6 inches)) and fasten them with appropriate screws.
It’s essential to pre-drill and use metric screws, which provides more safety and reduces damage to the material.
DEOLAU
13 Apr 2023 10:36
Always loosely mount the wall cabinets completely on the wall first before tightening the screws. This way, you can fine-tune the alignment.
Use appropriate wall plugs for the wall type and check that the cabinets are properly hanging on the rail. If in doubt, secure them additionally with brackets or supports from below.
Jukla66
14 Apr 2023 07:51
Thanks for the clear assessment. I’m now seriously considering using a wooden batten as a substructure.
SANMAR schrieb:
I use simple, galvanized steel brackets that are properly sized (at least 40mm x 40mm (1.6 inches x 1.6 inches)) and fasten them securely with suitable screws.
That sounds straightforward and practical. What kind of screws would you recommend: wood screws or machine screws with nuts? I’ve come across different opinions.
Also, what spacing do you recommend between the wall plug points when hanging multiple cabinets side by side? I want a continuous level without any tilting moments.
sarlo
14 Apr 2023 09:45
For the spacing of the mounting points, I rely on the drilling templates from Ikea, which are designed to optimally support the cabinet.
- If you hang several cabinets side by side, you can use additional connectors between them to increase stability.
- For screws, I usually recommend galvanized wood screws for wooden slats and metric screws for the wall plug area, as they provide better grip.
- Machine screws are rather uncommon for this type of installation, unless you have specific fittings that require them.
It’s best to check the alignment multiple times, especially before tightening the screws completely.
