ᐅ Which screws are the most important for assembling Ikea Metod kitchen cabinets?
Created on: 26 May 2021 08:17
Busin69
Hello everyone, I have a question regarding the assembly of the Ikea Metod furniture series: Which screws are truly the most important to ensure a stable and durable structure?
I mean, there are different types of screws included in the set (e.g., particleboard screws, dowels, cam connectors, etc.), but which ones should definitely not be overlooked or possibly even replaced with higher-quality alternatives? I am especially interested in the screws that have the greatest impact on the load-bearing capacity or stability of the furniture, particularly for base kitchen cabinets.
Thanks in advance for your insights!
Bagupo
26 May 2021 11:45
It is always important to screw in carefully, especially when working with particle boards. I use a cordless screwdriver with torque control.
The cam connectors provide stability, so make sure to align them properly beforehand, otherwise they won’t fit correctly later.
hauklo
26 May 2021 13:03
For clarification: With Metod furniture, the mechanical load-bearing capacity primarily depends on the chipboard screws, as they create the main supporting connections.
The cam locks and dowels are responsible for alignment and additional stability, but they do not replace the actual load-bearing function of the screws.
It is recommended to use only the screw types specified by the manufacturer, as these are matched to the MDF/chipboard material to prevent damage.
If you need to buy screws separately, be sure to choose the same sizes and materials.
lomin
26 May 2021 14:27
I can understand that it’s easy to feel uncertain sometimes. During my first kitchen installation, I was especially careful when driving in the chipboard screws because I wanted to avoid damaging the wood.
At that time, I even set a screwdriver with adjustable torque and worked step by step.
Still, I was occasionally worried that the screws wouldn’t hold, but that turned out to be unfounded.
Besides the chipboard screws, I believe the correct anchors should not be underestimated, especially at the corner joints, which later serve as important supporting elements.
Busin69
26 May 2021 16:02
Friedrich schrieb:
What are your experiences with driving screws? Are there common mistakes to avoid?
Thank you for your post; this is an important question. My biggest concern is applying too much force and damaging the chipboard.
Is it advisable to first insert all screws loosely and then tighten them fully afterward? Or is it better to fully tighten each screw as you go?
Are there specific tips to prevent the material from splitting around the screw?
Takutau
26 May 2021 16:45
Busin69 schrieb:
Is it better to first screw in all screws loosely and then tighten them fully? Or is it preferable to tighten each screw completely one by one?
In general, I recommend initially screwing all screws in loosely to allow the components to align properly. After that, tighten them evenly.
This helps prevent stress on the material and improves the fit.
To protect the particleboard, pre-drilling can be helpful if it hasn’t been done already, especially with thick screws. However, with Ikea Metod, the screws are usually matched to the material, so pre-drilling is not always necessary.
Slow and controlled screwing with torque control, when using a cordless screwdriver, is always beneficial.
EDWARD0
26 May 2021 18:00
Busin69 schrieb:
Is it recommended to first insert all screws loosely and then tighten them fully? Or is it better to fully tighten each screw one by one?
Both methods are correct.
First, insert all screws loosely, then tighten them evenly.
