ᐅ How can I efficiently install IKEA Metod cabinets with sliding doors in small spaces?
Created on: 5 Oct 2023 19:37
Turgut48
Turgut48
5 Oct 2023 19:37
Hello everyone, I’m planning to install IKEA Metod kitchen cabinets with sliding doors in a very small space and am looking for tips and experiences on how to do this as efficiently as possible. My main concern is to design the installation, especially the sliding door mechanism, so that I lose as little space as possible when opening the doors while still having enough storage.
I’m particularly interested in which fixtures or installation steps are important to mount the sliding doors securely and smoothly without making the workspace too tight. Are there any special tricks or additional tools that can make the job easier?
Thanks in advance for your detailed advice!
Jukin
5 Oct 2023 19:49
Hello Turgut48, your concern is very understandable because in small rooms, using sliding doors to make efficient use of space is a great solution but also a challenge. Generally, I would recommend checking first whether you have all the necessary fittings and tracks exactly as described in the instructions when working with IKEA Metod cabinets with sliding doors. The precise alignment of the running tracks is often underestimated, but it is extremely important for the stability and smooth movement of the doors. My tip would be to assemble the sliding door mechanism roughly without the doors and cabinet frame first, to check if the tracks run exactly parallel and if the doors slide easily. If that works, then you attach the cabinet frame. A level is also useful for checking, and small shims can be used if needed to compensate for uneven wall thicknesses. Additionally, do not underestimate the floor mounting because without a firm hold, the sliding doors are more likely to slip out of place. In general: accuracy before speed, and if possible, have a helper on hand to stabilize the doors and tracks when installing them.
Marlenepa
5 Oct 2023 20:04
I completely agree with Jukin and would like to go into more detail about the preparation. Especially in small rooms, space is often limited, so it is important to create a precise measurement plan before assembly. You should first measure the wall and check whether the cabinets fit exactly or if there are slight deviations. Then I recommend temporarily assembling the sliding doors with their tracks—preferably laid flat on the floor—to get a feel for how they work together. My experience with Metod sliding doors is that small inaccuracies in the tracks can later cause the doors to slide stiffly, especially if the cabinet body is restricted by the room. It is also important to test the door operation beforehand, as sliding doors require smooth rolling and must be easy to operate without much force. If you have already assembled the cabinet bodies but have not yet mounted the doors, you can usually still make minor adjustments. For wall assembly, I also recommend putting the cabinets together in small sections rather than as one large unit—this makes handling limited space easier.
LOGEMIN
5 Oct 2023 20:27
Hello Turgut48, I would like to provide you with a step-by-step guide to streamline the assembly of IKEA Metod cabinets with sliding doors designed for small spaces:
- Step 1: Measure the room and precisely mark the position of the cabinet. Allow at least 2-3 cm (1 inch) of clearance for ventilation and adjustment options.
- Step 2: Prepare all materials, including screws, rails, doors, and appropriate tools, to avoid unnecessary trips during assembly.
- Step 3: Assemble the cabinet boxes separately, but without doors for now. Make sure to check every corner with a level to ensure everything is perfectly square.
- Step 4: Install the sliding rails and door mechanism according to the instructions. It is essential that the rails are mounted straight and parallel, otherwise the system may become stiff or jam.
- Step 5: Carefully insert the doors. Once the doors fit, you can make small adjustments to the rollers if needed.
- Step 6: Secure the cabinets to the wall to ensure stability.
Common mistakes I often see: rails are not mounted at the same height, causing the doors to run unevenly. Also, too much or too little clearance on the sliding doors can cause issues. Another tip: if possible, apply a light silicone spray to the sliding rails to improve smooth operation over time.
If you have any questions about specific steps, I’m happy to help.
Deandre
5 Oct 2023 21:02
LOGEMIN schrieb:
Typical mistakes I often see: rails are not installed exactly at the same height, which causes the doors to run unevenly.
I also consider this a crucial point! I would add that when measuring the rails, you should double-check several times, for example with a long ruler or a straightedge. Additionally, in small rooms, you should take into account that the doors do not take up too much space in front of the closet when opened. Sliding doors save a lot of space compared to traditional doors, but sometimes the running rails require more space at the back than expected. If you really want to make the most of the space, it is also worth looking at different door models from IKEA, as some sliding doors are narrower and therefore better suited for small rooms.
Turgut48
6 Oct 2023 07:13
Jukin schrieb:
My advice would be to first loosely assemble the sliding door mechanism without the doors and cabinet frame, to check if the tracks run perfectly parallel and if the doors slide easily.
I will definitely try that, thanks! I’m also curious about how you handle floor fastening. Is there a trick to securely fixing the cabinets to the floor without damaging it or obstructing the doors? My flooring is laminate, so I want to avoid any damage.
